Starting Problem?
Old 11-10-2008, 06:18 AM
my4runner's Avatar
Starting Problem?
Cant figure it out, there are times when I go to start my 4runner, turn the key, all the indicator lights come on as normal, and it doesnt turn over,,,,I can hear the injector, but the starter doesnt even make a click...I found that when this happens, I am only getting 6 volts going to the starter, my battery is good, 12+ volts, my alternator is good, any ideas what would cause this? This doesnt happen all the time, just happens on occasion, I can push start it, or jump it without any problems when this happens.. any ideas?
Old 11-10-2008, 06:26 AM
89whitetoyota's Avatar
Location: Cincinnati, Ohio - Amelia is the exact place. There is no one else on this site from where I am. Seems like everyone is from Cali or Washington. I guess I need to move.
Hit your starter with a hammer a few times and then try to start it again.
Old 11-10-2008, 06:28 AM
4Crawler's Avatar
If you are only getting 6 volts at the starter:
- http://www.4crawler.com/4x4/CheapTri...shtml#EasyTest
Then there is a wiring issue up stream of the starter, see below for some ideas:
- http://www.4crawler.com/4x4/CheapTri...l#OtherOptions
Old 11-10-2008, 06:31 AM
22mr2's Avatar
If your only getting 6 volts to the starter, it sounds like there is a big voltage drop somewhere in the positive cable. Double check your connections at the positive terminal, if they are good, it somewhere in the cable thats giving you trouble. You could test the voltage drop on the cable, or just run a jumper cable from the starter to the positive cable to see if it fixes the problem when its acting up.
Old 11-10-2008, 11:45 AM
my4runner's Avatar
Thanks for the responses, I did run a hot wire from the positive post on the battery to the starter with the ignition key on, it started right up....let me ask you this, could the ignition switch be a cause of this? The ignition switch is kind of warn, I could start my 4runner with a knife or small flat object inserted into the key...thanks again
Old 11-10-2008, 12:14 PM
4Crawler's Avatar
Read the page I posted above, the 2nd link. There are two pats of the igintion switch, the tumbler that the key fits in and the contacts themselves.
Old 11-10-2008, 01:07 PM
my4runner's Avatar
Thanks 4Crawler, I will look into this this weekend, very good details on the starter...............thanks
Old 11-10-2008, 08:14 PM
marble_deluxe's Avatar
my truck was doing that too.
i found that if i took the disconnected the positive terminal and the reconnected it that it would start right up. i thought it was the ignition switch, but my starter solenoid went out.
bigjstang
08-25-2021 12:41 AM
06-01-2021 01:51 PM
Regency
20
01-03-2020 07:43 PM
Jnkml
07-06-2015 01:20 PM
Quick Reply: Starting Problem?
