Starting issues after sitting -Hilux Surf
Old 11-03-2009, 06:14 PM
SLOW240's Avatar
After much searching on many sites I have not found an answer to my issue yet, and I don't see a Hilux forum so I figure I would start here.
I've got a 1992 Hilux Surf with a 2.4 Turbo diesel (like the 80's pickups were available with). Everytime I leave the truck parked for a few hours, it won't start unless I hold the pedal to the floor. Even then it won't fire for quite some time, then runs rough for the first few seconds. I have checked glow plugs and such, but this is a fuel issue.
My fuel pump and filter are both new. The pump is all connected properly as far as I can tell, (previous owner installed it) and there are no obvious fuel leaks. I tried leaving it sit with the fuel cap off, no difference. If I pull the outlet line off the primer pump it will squirt fuel when I pump it, but if I put my thumb lightly on it, it doesnt build enough pressure to push my thumb away. The pump doesn't go hard no matter how much I pump it so I have a feeling the primer is failing. I was told to blow through a hose in the reverse of fuel flow to see if the check valve inside is any good. I did this through the filter/primer and no air seems to be escaping.
Where else should I look? I'm starting to run out of ideas at this point.
Regency
20
01-03-2020 07:43 PM
voiddweller
19
05-02-2016 09:10 PM
noahstancik
07-10-2015 11:18 AM
luke0927
07-02-2015 10:49 AM
slider417
06-22-2015 10:18 AM
Quick Reply: Starting issues after sitting -Hilux Surf
