Starter replacement
Starter replacement
I am in the process of replacing the starter on my 1988 4wd pickup. I was able to get everything disconnected (took the tire off to be able to work in the wheel well) and the starter is free. However, I cannot get the starter out. The largest path seems to be taking out the bottom by taking it back past the suspension brackets, but even that is too tight. Any tips?
bws
bws
Removing the starter in my 2wd 86 was a little difficult also. I had to go further up with it, rotate it, then bring it out from the bottom. The replacement was the smaller version, so it went in a little easier.
TURBOrunnerNM
07-22-2015 11:01 AM
ZONAYODA
07-13-2015 07:17 PM
