Starter/Ignition Problem 90 4Runner - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 02-06-2006, 07:57 PM   #1 (permalink)
Does anyone have any ideas why my truck won't start occasionaly?I turn the key.The dash lights up as usual.Nothing.Silence.I brought it to a garage and the mechanic said he had no problem starting it over 30 times with the key.He checked the battery,connections,wires,and starter.He said everything checked out ok.When it doesn't turn over with the key I can get it running with the remote starter.Sometimes it may take several tries.Suggestions?Thanks...
jm47 is offline
Old 02-06-2006, 08:28 PM   #2 (permalink)
trd90toyota's Avatar
Send a message via AIM to trd90toyota
Quote:
Have you looked at the starter contacts? This might be your problem. Simple thing to fix. Is it an aftermarket starter? Toyota's sometime have a problem with aftermarket starters.
Could it be the remote starter?
Anyone else chime in?
__________________
1985 TURBO 4Runner
22-RTE, 33x12.5R15 MT/R's, 1 Inch Shackles, Pro-Comp ES3000's, Trail Gear Sliders, 1 inch Wheel Spacers, FJ 62 Rotors, 87 Calipers, Cobra 18WX ST II, Custom K&N FIPK, Extended Diff Breathers, Custom Rear Swing-A-Way Bumper, Load Warrior with Hi-Lift, spare tire, 4 Hella 500's, 2 Pro Comp 55's for the rear, Addicted Off Road front bumper, Smittybuilt XC8, '00 Taco Rear End w/ E-Locker.
trd90toyota is offline
Old 02-07-2006, 01:44 PM   #3 (permalink)
Bobakazi's Avatar
Send a message via AIM to Bobakazi
I have the same problem with mine. Not sure what it is. Totally random. Every time I want to check it out, or have somebody else look at it, it is fine. Until you get it figured out, try this piece of advice that works for me and I have no idea why: When that happens again, don't sit there wiggling the key, don't try to turn it over many times. Try turning the key to the "on" position and just holding it there for a bit. Like I said, I have no idea why this works for me, but I do know that if I hold it there for a bit, (sometimes up to a minute) it just fires up. I also recommend for the meantime keeping a hammer in your cab. If worse comes to worse and you are stuck, try tapping on your starter before you get it towed. And if it is a 5sp, you can always pop the clutch. And of course, loosen your battery terminals, hit them with a wire brush and some baking soda/water mix, and make sure your wires are tight on the starter.There is also a wire going from the battery to the fuse box. Make sure both ends of that are clean and tight.
Post what you find out. For me it is just a nuisance, but I would like to correct my problem as well.
__________________
'90 Extra cab V6 4x4 PU
5.29 gears. Detroit locker front, Detroit Truetrac rear.
35" BFG mudders. Trailmaster 4" susp, 3" body lifts. Add-a-leaf. K+N intake, 2.5" exhaust with Flowmaster 40 and a cat I got off an Evo VIII.
Bobakazi is offline
Old 02-07-2006, 02:29 PM   #4 (permalink)
I had a similar problem on a 90 model Corolla. The starter, itself, was fine. But the contacts needed repair. Seems pitting is a fairly common issue wiith these older Toyotas. Once they get pitted, they don't flow current very well. That may be why 'holding it for a minute or so' per Bobakazi's method works. The battery finally draws enough juice to make it jump the gap. I finally took mine in to my mechanic and he built up the contacts by brazing and then filed them flat. That took care of it.
Bobakazi is right on the other steps. Loose or corroded battery terminals will have a similar effect. My only caveat would be to take care when using the 'hammer' method of tapping the starter while someone else holds the ignition key in the 'start' position. Don't hit the case too hard or you'll have starter parts falling apart inside the case.
Mike in AR
regularguy412 is offline
Old 02-07-2006, 02:39 PM   #5 (permalink)
VA_Yotaman's Avatar
I have had a horrible time with starters on my truck. Like someone said before, keep a 2' length of pipe and a hammer in the truck. When it acts up, place the pipe on the starter, and tap with hammer. When my first starter went bad, it would do nothing. No grinding, just silence.
__________________
1991 SR5 4x4
VA_Yotaman is offline
Old 02-07-2006, 08:23 PM   #6 (permalink)
Thanks guys.Working fine.It's the origional starter(188k miles).New battery.New battery cable ends.Mechanic said everything checks out.Could it be the ignition or the remote starter?
jm47 is offline
Tags
1989, 4runner, 85, 90, 92, ignition, jump, problem, problems, runner, start, starter, starting, toyota, turn, works
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Help Replacing Starter(90 4Runner) jm47 86-95 Trucks & 4Runners 6 10-08-2009 11:05 PM
1990 4runner starter problem 4x4_Ferg 86-95 Trucks & 4Runners 9 02-15-2007 02:54 PM
Starter Problem or Ignition Switch Problem? highplainsdrifter 95.5-2004 Tacomas & 96-2002 4Runners 0 11-12-2006 05:14 PM
I Need Diagnosis Help: Ignition? Starter? hhinojosa Maintenance & Repair Archives 4 11-22-2004 03:24 PM
90 4runner fuel problem need help AbramHart 95.5-2004 Tacomas & 96-2002 4Runners 1 10-25-2004 08:01 AM
2009 InternetBrands, Inc.
