stalls easily and runs poorly when hot
so i have this weird problem with my yota as of lately. when i start it when its hot..it wants to stall so i have to rev the gas a couple times and itll smooth out..then if i start going..itll bog down and even some times skip and it has barely any power going up hills. the wiers part though is sometimes itll clear out..i cant really pinpoint this so any suggestions would be appreciated thanks!
Welcome to the club!
For you though, I'd check your ECT sensor, cold start injector, cold start injector switch, and make sure your idle air control valve is working properly.
22re I assume!?
FSM
http://ncttora.com/fsm/index.html
22re I assume!?
FSM
Poncho0206
07-10-2015 06:21 PM
crashburnoveride
07-10-2015 06:39 AM
Jnkml
07-06-2015 01:20 PM
