stalling problem.
Old 11-03-2008, 06:10 PM
92yotaman's Avatar
stalling problem.
ok my 92 pickup has a 22re, the problem is that when im using a lot of electronics it stalls. Like when i have the lights on then i cant turn the heat fan all the way up or it starts to jump and sputter. On hills it cant even go up, and when i stop and keep it idling; if i put the windows up, when they get to the top, it will stall the motor. So i was thinking, maybe the alternator is old and sucks, or maybe something isnt grounded right. Im lost
Old 11-03-2008, 06:18 PM
iamsuperbleeder's Avatar
give er some gas then; problem solved
no seriously, you might just want to have the alt tested
what are you idling at with no draw on the system? RPM and voltage wise...
Old 11-05-2008, 10:10 AM
92yotaman's Avatar
more gas doesnt help. i think it might be the alternator, but i idling around 1500, but still have plenty of amps
Old 11-10-2008, 12:56 PM
92yotaman's Avatar
bump... any ideas
Old 11-10-2008, 12:59 PM
904_runner's Avatar
I think you are idling way too high. I idle at 800 rpms.
Old 11-11-2008, 09:51 PM
Bill54880's Avatar
Sounds like a weak alt causing poor spark when its over drawn. Check the spark when it happens. Spark should be bright blue not yellow or white.
Old 11-13-2008, 11:50 AM
92yotaman's Avatar
thanks the alt seems to be a good suspect
Steven.m.paulk
06-07-2020 10:45 AM
Kamaloha
10-16-2015 05:13 PM
alexcarey
10-14-2015 06:05 PM
charlie_fong
09-27-2015 10:06 PM
taraf
09-25-2015 02:57 PM
Quick Reply: stalling problem.
