Stabilizer Bar
Stabilizer Bar
My driver side stabilizer bar is busted, and I am looking to replace it. I have a 92 pickup with a 5 inch suspension lift and 3 inch body lift. Does anyone know if the stabilizer bar would still be stock and I could get one from the dealer? I measured it, and it was roughly 5.5 inches. The lift is from super lift, so if the part isn't stock should I try them, or are there any other suggestions?
Thanks for the help. It's much appreciated.
Just the end-links of the swaybar. Take the old one into NAPA & have them match it, shouldn't be more than 20 bucks to do both sides. Factory Service Manual says to torque those bolts at 9 ft-lbs
those style sway bar links are cheap, just get a pair from your local parts store (NAPA, CarQuest, whoever you like), or if you want to get super fancy I think Energy Suspension makes kits with pairs of them and poly bushings (generally available at a lot of parts stores as well)
kawazx636
10-06-2021 03:03 PM
WTB[PacNorWest]: Old Man Emu Torison Bars
A2theK
10-14-2015 07:10 AM
