SR5 Gauge Swap problem Fuel guage reading FULL
Swapped the DLX cluster for the SR5 cluster and everything is fine minus the tach not working (its probably not wired) and the gas guage reading full even when the truck is off. The truck doesnt have a full tank so its wrong. I reconnected the old cluster and everything is fine so I dont know what the problem is
Cluster is from an 89 4runner 22re 5spd
my truck is an 89 4runner 22re auto
1 Post
auto to man is different theres more to a auto then the 5-speed i did the same but i have the sr5 thinking that my cluster was bad fuel gauge didnt work come to find out its the sender all wells but yeah try it again with the auto cluster and DONT FORGET TO SWAP OUT TH OIL SENDER GET THAT FROM THE SAME TRUCK YOU GOT THE CLUSTER FROM
Would the sender readings be diffrent form an Auto to a Manual? My Temp Guage in funky too.
Any ieda if the Tach will work buy just plugging it in or do I have to run a wire?
1 Post
not sure i just know that with an auto theres more lights and for a stick theres not so much i have one for a 5-speed in milwaukee but if you want it your paying for shipping 10 bucks if wanted
the1998sr5
10-19-2016 12:48 PM
