SR5 gauge cluster swap problems
Old 03-12-2016, 11:01 AM
matt92yota's Avatar
Exclamation SR5 gauge cluster swap problems
Hey all, I've tried searching and couldn't find anything related to the problems im having. I have a 92 pickup 4cyl and I'm in the process of swapping in an sr5 cluster, I've got it in and the rpm and fuel gauges work fine I'm not sure about the oil pressure gauge as i am still waiting on the sensor to come in the mail. The problem I am having is with the voltage and temperature gauges both shoot up to max when I turn the key on and it stays there while the truck is running, anybody have any ideas on how to fix this?
Old 03-13-2016, 03:43 AM
wyoming9's Avatar
Red face
Since I am guessing you did not buy a Brand New Cluster
a poor connection could be a bad trace
Could be one of the connectors is corroded (unable to be seen with your naked eye)
Poor ground.
It could be possible some pins need to be moved impossible to tell without EWD
Your Cluster came out of the same year and model engine etc ??
Old 03-13-2016, 09:14 AM
matt92yota's Avatar
The cluster came out of a junkyard v6 4runner, I can't remember what year model it was though. Maybe I just got a bad cluster, but I will check grounds and connectors.
erock13
03-20-2016 08:36 PM
68jimmy
03-05-2016 05:47 PM
Ritzy4Runner
01-25-2016 01:03 PM
d-wood
01-20-2016 11:16 AM
Quick Reply: SR5 gauge cluster swap problems
