SR5 Cluster question (manual cluster fitting in an auto rig) - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 01-12-2008, 08:35 PM   #1 (permalink)
eightnine's Avatar
I know this has been talked about a lot and i have searched but I couldnt find anything specificly to a manual tranny cluster fitting in an auto tranny rig. I bought a cluster from an 89 4runner w/ 22re 5spd for cheap hoping it will fit into my 89 4runner w/ 22re automatic. Does anyone know if it will be a direct fit (minus the ECT button no longer working on the cluster)Thanks
__________________
1989 Toyota 4runner Special Edition
- Rebuilt 22re bored .20 over 4.30 gears, - Magnaflow Performance Exhaust with Magnaflow Hi Flow Catalytic Converter, Monroe Sensa-Tracs Shocks all around, 4runner AALs, Custom Checkerplate front skid plate, Kayline Soft Top , Clear Corners and Turn Signals, Eagle Alloy Rims with 31x10.5x15 M/T tires, 2 12" JBL Subwoofers / MTX AMP, Pioneer Premiere Speakers, JVC KD-G730 MP3/CD/Bluetooth
eightnine is offline
Old 01-12-2008, 09:02 PM   #2 (permalink)
eightnine's Avatar
buuuump
__________________
Old 01-12-2008, 09:28 PM   #3 (permalink)
yota4runna's Avatar
Are you referring to the instrument cluster?
yota4runna is offline
Old 01-12-2008, 09:29 PM   #4 (permalink)
eightnine's Avatar
Quote:
yes the SR5 cluster with the tachometer
__________________
Old 01-12-2008, 10:03 PM   #5 (permalink)
yota4runna's Avatar
Quote:
Well, I wasn't sure, since there's no ECT button on the instrument cluster. For upgrading from a standard to an SR-5 cluster it's "plug and play" except for these things: The standard cluster has an oil pressure warning light, activated by an oil pressure SWITCH, and the SR-5 has a gauge, controlled by an oil pressure SENDER. You MUST install a SENDER for your SR-5 cluster, or you'll ruin your gauge. Also, if your rig is a 4 cylinder, the donor rig must be a 4 cylinder, too, for the tach to work correctly.
Since Toyota is so good about interchangeability, this cluster is designed to fit different vehicles with different options. If you remove all the warning lights that run vertically along both sides and shine a light from the back, you'll see all the possibilities. The second from the bottom on the left is "AT Oil Temp" which won't have a bulb in it if it came from a manual trans rig. I suspect if you put a bulb in it that it'll work. I was impressed to see the "Low Fuel" warning light work when I did this upgrade on my '86.
Old 01-13-2008, 07:21 AM   #6 (permalink)
eightnine's Avatar
So are you saying that the clusters are all exactly the same where auto or manual except for the manual not having some bulbs that the auto would have?
__________________
Old 01-13-2008, 07:28 AM   #7 (permalink)
eightnine's Avatar
I just took all the lights out of the back of the cluster and found that the cluster did have an AT Temp light on it like you stated. It also has the T-Belt on it but it had no light on it so im guessing this is because the 4 cyl didnt have a Tbelt? So basically if there is no light in the hole then the truck didnt have have that option or whatever on it. Anyone know where i can get these bulbs at?
__________________
Old 01-13-2008, 09:31 AM   #8 (permalink)
yota4runna's Avatar
Just take the extra bulb and socket out of your old cluster!
Old 01-13-2008, 09:34 AM   #9 (permalink)
eightnine's Avatar
so the bulbs are the same then, ok cool thanks
__________________
Old 01-13-2008, 09:39 AM   #10 (permalink)
yota4runna's Avatar
Don't forget to change out your oil pressure switch for a sender. You're welcome.
Old 01-13-2008, 12:47 PM   #11 (permalink)
On my cluster swap on my '85, I put an EFI, manual trans cluster, in my '85 EFI auto. As yota4runna says, ya gotta replace the oil pressure switch with the oil pressure sender.
You'll lose the ECT indicator light, which ya don't need anyway. Most important for me was the need to compare the wiring harness plug from the manual donor truck, with my auto wiring harness. I had to rearrange some wires in my auto harness plug to make em match the same wires in the manual harness plug. Ya need a sharp pointed tool to release the catch holding the wire in place. After that, it was plug and play, and everything worked right.
__________________
turtle_jim@hotmail.com
turtle jim is offline
Old 01-17-2008, 04:17 PM   #12 (permalink)
eightnine's Avatar
i just called up the dealership and they want $120 for the sender!!! daaamn i thought it was gona be around 30$
__________________
Old 01-17-2008, 04:51 PM   #13 (permalink)
Trustyrusty's Avatar
Get in the zone, Auto-Zone...
__________________
1995.5 Tacoma 4X4 3.4-Jardine Catback, 20% Tint, Cold Air Intake, Skid Plates etc...
1987 Toyota 4Runner
1986 Toyota 4X4-SOLD
Trustyrusty is offline
Old 01-17-2008, 06:25 PM   #14 (permalink)
Jay351's Avatar
Send a message via MSN to Jay351
Canada = no autozone
Just go to your local parts store
__________________
91 Pickup - xcab - 5sp - 3.0 - SR5 - 4x4 - 250k |2.25" catback w/ magnaflow cat + glasspack | Weasy2k cams | Aisin manual hubs | Diff breather mod| Marlin HD clutch |3" BL | es3000's |2" AAL |1.5" bj spacers | ISR | Alpine headunit | 4" Infinity fronts/5" rears | 4.88's |Rear lockright | 33x12.50" BFG M/T on 15x8" steelies |Hella 500's |4" reverse lights| Grant GT |idler arm brace|hella E-codes| Marlin armor |SS IFS brace | %100 Amsoil synthetic
http://www.cardomain.com/ride/2572486
Jay351 is offline
Old 01-18-2008, 12:47 PM   #15 (permalink)
eightnine's Avatar
damn this swap is turning out ot be a damn headache. I got the oil pressure sender from parts source and they gave me the wrong one, its to small ... so i unplugged it anyway to test out the SR5 cluster. After finally ripping out the old cluster with the damn anoyying speedocable i attached everything back and its not working properly. The Fuel Guage reads at FULL even tho there is barely any gas in it, the speedo doesnt work and the tachometer doesnt work either. Some lights on the left side dont work either.. Anyone know what it could be?
BTW cluster is out of a 89 4runner special edition 22RE 5spd
and i have a 89 4runner special edition 22re auto
__________________
Old 01-18-2008, 04:52 PM   #16 (permalink)
eightnine's Avatar
Buump
__________________
Old 01-18-2008, 05:12 PM   #17 (permalink)
eightnine's Avatar
update: everything works now except the tachometer (i guess its not wired) and the fuel guage is still reading full when its not
__________________
Old 01-18-2008, 08:37 PM   #18 (permalink)
just a 22re's Avatar
Send a message via AIM to just a 22re Send a message via Yahoo to just a 22re
hit the cluster they may be stuck my tach in my neon did that all the time when i reved passed 9.2k it sucked but i got a 5in monster tach siting right next to my cluster that works the best and you get a shift light when your bogin or mudding so you dont over rev your rig!!!
__________________
GO TEAM LAZY!!
my name is ALLAN
yeah its a 22re 5-speed 4wd 1987 4runner with a cam, snorkel, welded rear
Quote:
Originally Posted by SwampThing View Post
Going wheeling and going swampthinging are two totally different things. Wheeling is doing something with the expectation of having fun in the process. Swampthinging is doing something and knowing you'll probably end up in a hospital in the process.
http://www.yotatech.com/misc.php?do=flashchat
www.myspace.com/whatsadisplayname
just a 22re is offline
Old 01-29-2008, 12:14 PM   #19 (permalink)
89RUNNERFFD's Avatar
I just installed an 88 SR5 Cluster from a Auto 4 cyl in my 89 6cyl Auto. It works great. I was woried there would be problems.
89RUNNERFFD is offline
Old 01-29-2008, 12:21 PM   #20 (permalink)
muddpigg's Avatar
Watch out for Niehoff (sp?) the parts number referance was wrong at Schuck's or manucactor. Look like the correct sender but fried the gauge all the same
They gave me a correct sender and my money back. Now need another sr5 cluster. oh well.
muddpigg is offline
Old 01-04-2009, 07:39 PM   #21 (permalink)
Windsor's Avatar
bumping an old thread...
I just did this with my '87. I haven't changed the oil sender yet, but it cost me $40-ish from Pep Boys.
One question I have, though, is what is the friggin' part number for the smaller bulbs in the back? The old (non-tach) instrument cluster only had one size of bulbs -- the bigger ones. The new one has two sizes and I managed to come up one or two short of the smaller ones.
None of the non-dealer shops had the bulb listed. The dealer quoted me $2/ea and said they didn't have them in stock (and didn't volunteer the p/n, of course).
__________________
'87 T4R Deluxe, mall crawler
every non-SR5 option installed (sans AT), as well as:
* Cruise Control (dealer installed)
* Michelin LTX A/T2 31s on 1st-gen alloy rims
* SmittyBilt granny step bar
* SR5 Instrument Cluster
Windsor is offline
Old 01-05-2009, 09:31 AM   #22 (permalink)
yota4runna's Avatar
The tiny bulb in the instrument cluster is a #74. Should be available at your local parts store.
Old 01-05-2009, 11:05 AM   #23 (permalink)
Windsor's Avatar
Yeah, I need to get the carrier also.
__________________
Windsor is offline
Old 01-05-2009, 03:55 PM   #24 (permalink)
4runnerx3's Avatar
Speed sensor no. 1 is in the instrument cluster which the ECT control unit reads. Only auto cluster has it.
4runnerx3 is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
SR5 Gauge Cluster Question myyota 84-85 Trucks & 4Runners 3 05-30-2007 10:28 PM
Wtb: 89' V6 4x4 Auto Sr5 Pickup Speedometer Cluster 2000 stang 86-95 Trucks & 4Runners 2 04-05-2006 09:04 PM
SR5 T100 Instrument Cluster Question dynamic73 86-95 Trucks & 4Runners 0 03-23-2006 03:45 PM
2009 InternetBrands, Inc.
