sr5 cluster into 93 pickup
hey ppls im stuck i need help .... well wat im doin is tryin to put a 92 four runner cluster in a 93 pickp and all the clips plug and play and the mile per hour work and fuel temp and odometer work and im tryin to figure out where to place the wire and which clip in cluster does the rmp signal wire goes any info will help thanks
You need the combination meter wiring diagrams for each vehicle to see what goes where. I have them for the '93 truck and '91 4Runner but they are too large to upload here. PM me an e-mail address and I'll send them to you.
Did the dash that you pulled out have the tach? If not the wire harness probebly does not have that wire in it. I had to go through this with the diesel install. I had to run the wire to the proper pin. Number 7 on the connector closest to the drivers door.
thanks cadman i got it ... but no my old cluster did not have a tach on it before ... but do i have to run a wire from the coil to the #7 pin on the clip or do you have to combine wires to make it work
yotagon400,
The pdf for the '93 truck should also have the wiring diagram for the cluster without the tach, but yes, all you need to do is run a single wire from the igniter to the tach pin on the cluster.
One more thing you need to change. If your stock gauge has the low oil pressure warning light and the new gauge has the oil pressure gauge, you'll need to remove the oil pressure switch and replace it with an oil pressure sender.
My DLX did not have the cluster with the tach, oil pressure gauge, voltmeter, or reserve light. That was probably an option on models with manual trannys, autos don't really need a tach. The Toyota FSM shows both clusters in the Body Electrical section. I personally think the DLX cluster looks better, but I wanted all of those dodads.
ok sry if i confused you guys but i have a 4cyl and my old cluster did have the oil press,volt,or a tach. all it have was the temp fuel and speed, and the new cluster that i purchased has all those gauges and i plugged it in and theonly thing that works is the speed, fuel , temp , and volt , and im tryin to figure out how to make the rpm to work and wat wires to connect
You have the same that I had. V6 auto gauge package, all dummy lights and a speedo. Everything was there for the other gauges just not the tach wire.
Search and you shall receive. I knew there was an early writeup somewhere:
https://www.yotatech.com/forums/f115...ictures-51800/
Read the entire thread.
09-04-2015 09:27 AM
