Squealing Clutch!! Need help!
OK so I have put in a clutch last week and after I put everything back together when I crank up the truck and pressed in the clutch it squealed like hell. when I took it back apart I realize the throwout bearing had seized up and had also ate the pressure plate.so today I put in a new clutch and another new throwout bearing and when I put it together every time I press in the clutch it is still making a God awful squealing noise.both times I put in all new parts so I don't know what could be going wrong here I am extremely aggravated and tired and worn out so please somebody help thanks in advance
Staff
I have had a throwout bearing to seize as well. It is possible to get the clutch disk in backwards. The big flat part goes toward the flywheel and the hub goes toward the transmission.
Another area is are you getting the throwout bearing mounted correctly? Some use 2 black clips and one uses a wire like device to hold it on.
Brand new pilot bearing. I put in the same pressure plate as the one i put in last weekend it was brand new but had gotten chewed up some from something going wrong when I first installed it. The teeth looked a little uneven do you think that could be a major issue?
definitely. first thing is why are the teeth uneven? find the answer to that and you might find the problem. could be a warped pressure plate or flywheel surface, or could be a small grain of sand caught in there somewhere. the pressure plate might need rebuilding again. you need to tear it apart and inspect carefully.
when you are not releasing the clutch, there is no pressure on either bearings or the pressure plate, and everything else is just locked together. i usually clean the bore real good and use bearing mount on the pilot bearings. it has a while to cure, so starting up once done centeres the bearing good. i can explain it 6 ways from sunday, but bottom line is the squealing means that metal is rubbing metal, rather than bearing spinning freely between the parts.
According to the FSM, the teeth are supposed to be aligned within .020" of each other, so if you can see the misalignment they are way out of spec. The result of the misalignment is a rocking motion on the TOB as the pressure plate turns, which causes the TOB to move on the transmission input shaft housing, causing a squeal. Usually this shows up as a squeal when the clutch is fully engaged and your foot is off the pedal, but I suppose it's possible that a severe misalignment could cause the problem when the clutch fork is applying pressure to the TOB.
The rocking motion and squealing is a classic Toyota problem, and still shows up on late model Tacomas and FJ Cruisers. Google "Toyota clutch chirp" for more info.
I don't know if this is your problem, but I would certainly get those teeth aligned, because if you don't you will have the problem I've described above, and while relatively harmless, it'll drive you nuts.
Some other things to throw out there. Is the flywheel fully seated on the crankshaft?
Did you use a torque wrench and a progressive increase in torquing?
What brand clutch kit are you using?
Did you use the alignment tool on the friction disc?
Did you use s torque wrench on the pressure plate.
I've seen people smash the dowel pin on the crankshaft and have the flywheel all jacked. I've seen pressure plates unevenly torqued with the fingers all cockamamie. I saw a shade tree mechanic clip the balance weights off a Centerforce clutch because he thought they looked funny
you have to remember that it's opposite of a disc brake. when you don't touch it, everything is locked together and the throw-out bearing is just basically sitting there on the shaft free-spinning. when you release the clutch, you are putting pressure on everything but the clutch plate. if the fingers are not lined up even, then something wasn't bolted down right/square. take it apart, check why and do it again. if you can afford it, moly graphite paste is awesome on sliding wear surfaces, like the pilot bearing where it contacts the fork, shaft, and pressure plate fingers, and where the fork rides on the ball.
I'm reluctant to suggest faulty hydraulics, because as has been said, that is the opposite direction of resting force.
Hundreds of pounds of force wants to clamp the pressure plate.
primordialbeast117
12-19-2015 12:23 PM
smilen724
13
11-08-2015 04:11 PM
hiluxinargentina
09-30-2015 11:12 PM
hiluxinargentina
09-30-2015 05:51 PM
