sputters and no power when ran for a little bit
Old 01-30-2015, 09:44 AM
92yote4x4's Avatar
92 3.0 v6 4x4 a/t, the longer the truck seems to run the worse it gets, it being hot or cold doesnt affect it, if i shut the truck off and start it back up it run fine for another 5-10min. i have put a brand new fuel pump in it (it helped) cap, rotor, wires, plugs, fuel filter and coil are brand new, checked distributor pickup coil all is fine, it was throwing a code for egr 2 weeks ago and now it all sudden is gone, i have no codes now, i got one when i was flooring it and it was sputtering and it threw a code 25 for lean but 5 miles down the road it went off. i have no idea as to what it could be, my ecm got wet a couple days ago and it died out on me but it was doing this before all that happend. ive been driving it around like this for the past month and shutting it off at red lights so i can leave the red lights normally and not like a grandma. any and all help is greatly appreciated!
Old 01-30-2015, 02:42 PM
92yote4x4's Avatar
Bump anyone i need this thing its my daily
Old 02-01-2015, 07:44 PM
92yote4x4's Avatar
Bumpp
Old 02-02-2015, 09:49 AM
92yote4x4's Avatar
come on really no one has any input to this?
Old 02-02-2015, 10:04 AM
bswarm's Avatar
Well, could be clogged exhaust. That usually gets worse the harder you push the throttle. Does it misfire? Does the exhaust sound like a hoover vacuum cleaner? Vacuum test? Compression test?
Old 02-02-2015, 11:01 AM
92yote4x4's Avatar
Exhaust is clear and the longer i run the engine the crappier it runs but i can shut it off and turn it back on and its back to normal
Old 02-02-2015, 11:47 AM
bswarm's Avatar
Did you replace the sock filter on the end of the fuel pump?
Old 02-03-2015, 06:43 AM
92yote4x4's Avatar
yes was replaced along with pump
Charecter1
11-06-2023 10:08 AM
Sleaker
08-26-2020 06:03 AM
Jeffreynmandy
07-18-2015 08:26 AM
cars-guy
07-11-2015 07:51 PM
Coreyr384
07-10-2015 11:13 AM
Quick Reply: sputters and no power when ran for a little bit
