sputtering 22re
Old 03-10-2009, 07:27 PM
92toypunk's Avatar
Question sputtering 22re
cold engine runs fine, as it warms up it when accelerating sputters, almost as if there is a vacuum leak?? i can feel a power lag while accelerating
Old 03-10-2009, 07:30 PM
Staff
DeathCougar's Avatar
I ran into this problem in my 86. It was cured with a new EGR valve.
Old 03-10-2009, 07:35 PM
abecedarian's Avatar
does it go away when fully warmed up?
Old 03-10-2009, 07:37 PM
92toypunk's Avatar
no it gets worse.
egr valve huh? local auto parts store should carry this right?
Old 03-10-2009, 07:44 PM
Staff
depends. some do, some don't. You might be able to find them used, but for me I usually can't find them in good shape used. If you can't find them new at the parts store, try toyotapartsales.com which sells OEM parts at actual discount prices
Old 03-10-2009, 07:58 PM
You may also have 1 or more injectors that have bad spray patterns. When cold, the ECU holds the injectors open longer to create the rich mixture a cold engine needs then shortens the injector pulse as the engine warms up. If (an) injector(s) are bad, as the engine warms and the pulse shortens, it could turn from an acceptible spray when cold to a stream when warm, causing an issue with proper combustion in the engine.
A dribbling cold start injector could also cause similar behavior as could valve adjustments, a failing coolant temp sensor or even a vacuum leak.
Charecter1
11-06-2023 10:08 AM
izzmee
08-17-2015 10:20 AM
Sidherish
08-02-2015 01:42 PM
montanatruck
07-25-2015 03:45 AM
Quick Reply: sputtering 22re
