Spotlights
Spotlights
Does any body have a spotlight in their 4runner, one thats built-in that you can control from the inside, while your driving, just like police cars?
I think that would be sickkkk to have one, or maybe even two, for both the driver and passenger. So if anyone has had it done, knows someone whos done it, and level of difficulty to do so let me know please. Thanks
Try one of these. My brother has one on his boat.
Model: Golight Stryker
Color: Camouflage (black, white and chrome models available)
Pan and Tilt: 370 degrees rotation with hard stop. 140 degrees tilt to direct upward beam position
Mount: Permanent or Detachable. Also available with magnetic mount
Voltage: 12 Volts DC appropriate for most consumer vehicles, off road vehicles and small boats (24 Volts DC available in the 24 Volt Golight Light Category)
Lamp Wattage: 65 Watts
Amp Draw: 5.5 amps on 12 Volts DC
Cord: 1 foot pigtail with stripped and tinned leads. Operator must provide wiring (16 AWG) from battery and/or fuse box to the light.
Beam: Wide Spot beam - effective working beam of 850 feet (can read a book at 850 feet)
Lamp Construction: Phillips bulb and glass lens/reflector assembly (Golight spare bulbs available here)
Industrial Candlepower Rating: 500,000 (original GE formula used in OEM/industrial) more on candlepower
Retail Candlepower Rating: 6.5 million (newer formula used in retail stores) more on candlepower
Remote Type: Wireless
Remotes Included: Handheld and Dash Mount - battery operated
Dimensions: 6 inches wide by 6 inches deep by 7 inches tall
Weather Rating: Weatherproof
BlindfoldMemphis
08-15-2012 02:02 PM
85gijunk4x4
77
09-06-2010 03:22 AM
12, 24, boat, candlepower, ge, golight, industrial, level, model, older, rating, retail, spotlights, store, volts
