speedometer and odometer dosent work
Take it out of the transfer case and put a drill on it. You can turn it with the drill to see if it turns the speedo/odometer. You'll find out quick if the cable is broken inside the sheath or there's a problem behind the gauges. I believe you can also look inside the hole on the transfer case and check the teeth on the speedometer gear. Pull the gauges, remove the speedo cable from that end and turn the drill again. That'll tell you if the speedo cable is broken. If the cable turns and the teeth in the transfer case look good then the problem is in the gauge.
ashersullivan88yota
01-18-2022 05:37 PM
09-04-2015 09:27 AM
crashburnoveride
07-10-2015 06:39 AM
madxman21
07-09-2015 10:26 AM
