Speedometer/Odometer
Hey guys,
Bought my first 4runner. It's a 92 3.0 automatic. I bought it with the speedometer and odometer not working, figured it wouldn't be a hard fix. Now I'm coming to you for some expertise.
I've done some research, although it seems it's hard to find viable information. I have removed and inspected the speed sensor at the xfer case, even bought one from a junk yard just to try. So far I've had no luck getting it to work. How do you troubleshoot these as it is a 3pin connection? Not sure the correct steps to take. Thanks guys.
I assume you have the electronic VSS1.
I have attached a drawing of the connector. The component is an IC with an integrated hall-effect sensor. You need 12v and gnd to power the IC, and the signal is 0 or 12v.
Since you've taken a chance on a junk unit, the first thing to do is to test it. Battery voltage can power it, and a multimeter can pick up the signal. The hard part is connecting to the pins of the connector, but it can be done.
On mine, I tested in the opposite direction, but you'll need a signal generator to do that.
Someone on this site reported finding the component filled with oil (bad o-ring). He cleaned out the oil, and the component started working again. I suppose it's possible ...
_RaStA_RoCkEt_
06-10-2017 03:41 PM
eleazar1
01-02-2015 01:10 PM
FS[PacSouthWest]: 89 V6 4RUNNER A/T NO BODY & 87 4runner rollover
ChefYota4x4
05-26-2014 04:12 PM
