Speedometer making noise--22re
Old 04-24-2008, 02:21 PM
84 yota ex-cab's Avatar
I have a 22re in my 89 toyota 4x4 truck and it is making some weird noises. I squeaks and almost a grinding noise. Is this the cable or the speedo assembly in the instrument cluster?
Old 04-24-2008, 02:59 PM
86Original's Avatar
Probably the assembly in the instrument cluster. Mine's been doing that for years when it gets cold (< 30 degrees F). The colder, the noisier.
Old 04-24-2008, 03:41 PM
spokane.yota.man's Avatar
had the same thing on a corolla gts i use to have. only did it when its cold. i heard you can take the assembly apart and regrease the cable w/ lithium grease (i think). supposedly a lack of grease is what makes the grinding noise.
Old 04-24-2008, 05:01 PM
toyotanick's Avatar
are ya'll sure its not an exhaust leak at the header??? because i have heard plenty vehicles making a sound that sounded like a light clicking that speeds up as the vehicle speeds up and it has always been an exhaust leak at or near the header
Old 04-25-2008, 05:51 AM
86Original's Avatar
It's pretty easy to tell the difference. If you press in the clutch and rev the engine, noise frequency increases -> exhaust leak, otherwise speedometer noise.
okamikai
04-30-2018 10:19 PM
altydog
07-28-2015 10:20 AM
toyoterferdayz
Diesel Swaps
07-27-2015 05:25 PM
TammyMarie
07-15-2015 11:14 AM
wilbertd
07-06-2015 07:39 AM
Quick Reply: Speedometer making noise--22re
