Which speedo and park brake cables with body lift?
Old 05-07-2016, 05:34 AM
courchaine's Avatar
Question Which speedo and park brake cables with body lift?
Hey All:
I have a 1989 Pickup DLX 2.4 5speed and 4wd, Short bed and standard cab I picked up a few weeks ago. It has a 3" body lift on it.
I need to replace the speedo and front parking brake cables and wanted to know if you suggest using the cables from an extra-cab? I imagine they would be maybe a bit longer?
Any advice is most appreciated!
Old 05-07-2016, 07:36 AM
MudHippy's Avatar
In my experience a 3" body lift doesn't require either of those parts to be different than what was there from the factory. I can see no potential benefit from using longer ones.
Old 05-07-2016, 01:01 PM
wyoming9's Avatar
Red face
In fact they E-Brake cable would end up being to long !!
Nothing worse then a cable that is to long .
I found this out the hard way the extended cable was all I had on a long weekend
Old 05-07-2016, 05:54 PM
offroadnutz's Avatar
You could make your own like I did.
end
pully 1
connection
dif cable
