Sign in using an external account
| 86-95 Trucks & 4Runners 2nd/3rd gen pickups, and 1st/2nd gen 4Runners with IFS |
| Welcome to Yotatech! |
LinkBack | Thread Tools | Search this Thread |
#1 (permalink) | ||||
Personal
Sales Rating: (0)
Speedo Cable replacement, Help!
#2 (permalink) |
Personal
Sales Rating: (0)
If you are dealing with a V6 application, you'll be better off disconnecting the E-brake cable at the bell crank arm under the truck, and then back-tracking it (taking it loose) back to the cab. Pull it all into the cab, and then feed it back through the new speedo bracket, and put it back together.
I have also read that some people cut a notch into the plate of the new speedo cable, to make it easier the next time around. I have no idea if the 4 bangers are the same, or not. |
#3 (permalink) |
Personal
Sales Rating: (0)
[OP]
Yes, it's a V6. Seem's to me a fella out to be able to disconnect the cable at the handle, and slide the speedo cable and mounting plate up through the cab and over the end of the e-brake cable. Is this possible or is it more work that it appears? If do-able, how do you disconnect the the e-brake cable from the handle? Also, removed the speedo head and there was a lot of old grease splattered around the back of it. I cleaned it up up as best I could w/out taking it apart. Would really like to get it apart some more to clean it better, but not sure how to get the needle out to remove the faceplate and get to some screws to remove the rear of the housing.
Rick |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| speedo cable replacement ?'s | mt4runner | 86-95 Trucks & 4Runners | 5 | 11-14-2006 07:39 PM |
| speedo cable | 85TurboRunner | The Classifieds GraveYard | 1 | 03-26-2006 08:28 AM |
| Speedo Cable | quik05 | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 11-21-2004 11:31 AM |
| speedo cable help | anondrao | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 10-17-2003 05:21 PM |
| Speedo Cable | mrick | 95.5-2004 Tacomas & 96-2002 4Runners | 0 | 09-23-2002 05:43 AM |
