Speed Sensor Location
I think you mean rear of the transfer case (with a two-speed transfer case, it doesn't do any good to use the speed sensor in the transmission for the speedometer).
I believe the '92 has the electronic sensor, but if you find a speedo cable instead, you don't.
Good point. But this only applies to the cable-driven speedometer. If you have the electronic VSS1 on the transfer case, that replaces the reed-sensor in the cluster.
Mine ('94, 4x4) has the electronic sensor. I don't know which years/models that applies to.
92-94 are Electronic.
taller1
11-13-2018 02:34 PM
montanatruck
02-26-2017 07:07 AM
