speed sensor
Old 05-01-2007, 08:29 AM
cat321's Avatar
speed sensor
can anyone please tell me if there is a connection between speedometer not working and auto transmission suddenly not working at the same time. problem happens after driving several miles. 1993 2x2 T100 6cyl.
Old 05-01-2007, 09:02 AM
4runnerx3's Avatar
I'm sure it does, I know my 86 has a speedsensor (#1).
Old 05-01-2007, 09:10 AM
eric-the-red's Avatar
Sounds like a bad speed sensor in the trans, most of the electronic transmissions use the speed sensor to control shifting, and it also sends a signal to the speedo. Not sure about the price but it's easy to replace. You'll find it at the rear of the transmission.
Old 05-01-2007, 09:31 AM
slosurfer's Avatar
Yep, that was when I knew it was time to finally replace it. I just dealt with the funky speedometer for awhile since it would come and go, but then it started messing with the tranny. When I replaced mine, the dealership was actually the cheapest place to get them. Was an easy less than 5 min. fix.
The speed sensor is on the rear of the transfer case on the passenger side.
Old 05-01-2007, 10:12 AM
SteveO's Avatar
How much was the speed sensor?
montanatruck
02-26-2017 07:07 AM
ty1er
08-01-2015 11:53 PM
krimsonone
07-29-2015 11:53 AM
wilbertd
07-06-2015 07:39 AM
karbin
07-05-2015 11:37 PM
Quick Reply: speed sensor
