| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#51 (permalink) | |||||
__________________
1998 T100 Xtra Cab SR5 - Deckplate Mod - Rhinoliner - Bilstien Shocks - Extended Diff. Breathers - Manual Hubs - - TJM T-17 - Milemarker 9000lb Winch - Waiting to Install: - Leer Canopy - Yakima Loadwarrior - Rancho 26mm Tbars - |
#52 (permalink) |
The Campaign Number you need is 50N. This lets toyota know exactly what you are talking about. They are all confused at the customer care centers and dealerships. The will receive the distribution list next week. If they tell you u are not part of the recall tell them to check again or tryt a different dealer.
#53 (permalink) |
I called the toyota 1- 800 number, and they know nothing of my truck.
__________________
1992 4Runner SR5 V6 3.0L 4wd---In Germany 2000 ZR2 S10 4.3L Vortec--------In El Paso 1990 300zx 3.0l 2seater----------In El Paso 1975 Scottsdale stepside 350sb--In El Paso ROCK ON!!!!! |
#54 (permalink) |
My queastion is, has anyone taken their truck/4runner in to have it recalled with a lift of any kind? Or asked the dealership if the lift voids the recall? I am afraid to ask...
__________________
-Jake 1990 4Runner <> 1990 Toyota 4Runner-22RE-5 speed-TG 3" front/4" rear-35" BFG M/T-4.88's-rear LSD-front TruTrac-MC Rear Bumper-TG DOM Sliders-TG Front Bumper SAS Build-Up Old Rigs: '85 4Runner (RIP) '95 4Runner (sold) |
#55 (permalink) |
I don't think a lift will void this recall, unless it is a lift like mine that completely replaced the center link with an aftermarket part. A lift shouldn't make it any harder for the tech to replace the center link, it may however make it harder to do an alignment. I guess it's possible they may replace the center link for you then claim they can't set the alignment within specs because of your aftermarket lift. They could also claim (and rightfully so) that they can't set the alignment within specs because of your rusted or frozen adjustment cam bolts or your rusted or frozen tie rod adjusters. Working on the steering components of a 15 year old truck could be like opening a can of worms, especially if the truck has been driven in the rust belt for 15 years. I can envision all new front-end components (tie rods, ball joints, control arm bushings, adjustment cams, adjustment cam bolts, idler arm, pitman arm) being recommend for some at their own expense. It could turn into a real money maker for the service dept. You get a free center link but need $1000+ worth of front end rebuilding.
__________________
~Dale~ 93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000. Last edited by mt_goat; 09-20-2005 at 06:06 AM. |
#56 (permalink) | |
Quote:
email it to me and Ill host it. and post the link on this page |
#57 (permalink) |
i'd love to see that SSC document -- and have it on-hand when i go to the dealer for the service...
__________________
2006 V8 Sport Edition, Galactic Grey |
#58 (permalink) |
SSC Document
Link to SSC Document
Contains VIN's and info for recal Please Right Click and Choose SAVE AS http://www.mudrunner.ca/other/toyotaSSC.pdf |
#59 (permalink) |
excellent!
thanks very much 4hummer!
__________________
#60 (permalink) |
I heard that supposedly 7 relay rods have failed out of nearly one million trucks. Before you bash Toyota you should be thanking them for taking such good care of us. If GM, Ford, or Dodge did the same they'd go bankrupt. About 500 people need to have died before any of them will consider issuing a recall. With Toyota it takes some guy with 38" super swampers snapping his relay rod in the mall parking lot and one million vehicles get recalled for an updated part. Thank you Toyota for recalling my truck even though it has been in service for 16 years and 11 months. You guys rule.
#61 (permalink) |
I just took my Runner in to have the CEL looked into, Darn 25 AND 26 Codes! Anyway they are going to be replacing the rod. I looked at the work order and it says they will need to check and fix the alignment and toe-in/ toe-out FREE ALIGNMENT!!! On the house! HAHAHAHA!
__________________
1990 4Runner 4x4 3.0 Auto. Sitting on 31X10.50 Baja Claws, Aisin manual hubs, OME shocks & coils. Optima Redtop, 40 Series Flowmaster and High flow Cat |
#62 (permalink) |
WOW, Toyota customer service is great, I called them and they are going to repair my truck over here in Germany, and if it wasn't for this forum I wouldn't found out about the recall or Toyota's 1-800 number. Thanks guys.
__________________
#63 (permalink) |
1989 SR5 4X4 pickup. 16 years old...240 thousand miles.
Toyota is STILL looking out for their owners, even after all this time. Dealership is replacing my 'steering relay rod' as we speak. I didn't even know about this recall. My truck was in the shop for other reasons. They notified me of the recall. Doxon Toyota in Auburn, WA is OK in my book. Jim
__________________
'04 4X4 XTRA Cab SR5 V6 TRD Automatic..Sweet! '84 4X4 Standard Cab 22R 5-Speed Pickup..SA! 33X12.5 BFG-AT KO's**4.88 Yukons**Budbuilt Crossmember**OME Springs**Badland Bumpers, Sliders**Sky shock hoops**Bilsteins** |
#64 (permalink) |
I just checked my VIN and its in the list. NOw i just need to replace my inner and outter tie rods and steering stablizer b4 i take it in for the recall.
__________________
92 4Runner SR5 Aisin hubs,pin stripe removed,police scanner,brush guard,Monroe Senseatrak shocks and steering stablizer,Brembo rotors,Downey HD coils,Blue reverse indiglo guages. . . http://community.webshots.com/user/sludg3 |
#65 (permalink) | |
Quote:
__________________
~Dale~ 93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000. |
#66 (permalink) | |
Quote:
Anyone else know what to do? Anyone with a break down on what the actual VIN nos. & letters mean to see if it matches? |
#67 (permalink) |
Does anybody know if the SCC document includes the VIN numbers for the canadian trucks, Mine isn't on the list???
Matt
__________________
Matt 2003 4-Runner Limited - Couldn't stay away from the runner 2003 Sequoia Limited 1989 Supra Turbo 1992 4r, 5spd V6 Sold |
#68 (permalink) | |
Quote:
LeeBee, is your's on the list? Also LB, is your avatar taken in front of Sherwood Garden, in Ajax?? If so, I was there today, looking for it
__________________
91 4Runner, 5 spd, with the Mighty 3.0! 0 to 60 in 2.5 liters. |
#69 (permalink) |
Son of a...guess my truck makes 8 for the recall. I went to the junk yard to get a 20r intake manifold for my 83 20r/22r hybrid and as I was leaving the shop where my other truck was ....*Silence* the steering wheel turned both directions but the truck went straight. Luckily I was in a parking lot. And now it's going to be Monday before they can "look" at it. I can look at the stupid steering relay rod and see where it broke, about a inch from the pitman arm..oh well, I'm gonna give 'em a bit of crap, but not too much at least they're going to fix it...to be continued...
__________________
'97 T100 4" Pro-Comp IFS Lift 33x12.5x15 Xterrains Flowmaster 40 83 pickup 22r soon to be hybrid |
#70 (permalink) |
Wonder if they are giving out a rent a car if they are going to take their sweet time like they did with the head gasket replacement campaign.
__________________
Got a PDA? Stop on by!!! www.abfnet.com |
#71 (permalink) |
I'll find out Monday, I was supposed to leave today and go to Mississippi for two weeks for work. Now I can't go until my truck gets fixed or I get another vehicle.
__________________
#72 (permalink) | |
Quote:
Do you have photos of the brake? I would like to see if you do. Hope Toyota fixs it quick for you!
__________________
#73 (permalink) |
I was hoping to be able to keep the old parts, like I usually do, but they said that they have to send the old stuff in to Corporate. It will be tomorrow before they get the parts, so hopefully they won't have gotten rid of them when I go this afternoon and I can take a picture of it.
__________________
#74 (permalink) | |
Quote:
I'm afraid to go in and have it done because I dont want the "well, we need to replace that too" and end up with $$$$ to the stealer. Also who has the best svc dept. in DFW? thanks! Mike
__________________
1994 4Runner SR5 V6, 2nd HG, Downey headers and custom crossover, Aisin manual hubs, full OME suspension, Optima Red Top, Carsound hi-flow cat, Magnaflow with 2 1/4" pipe, K&N drop-in, Yakima rack, F/R diff breathers, BF Goodrich A/T's, ARB Bull Bar, "Highway Blaster" horns, more to come...... |
#75 (permalink) | |
Quote:
http://www.trademotion.com/partlocat...?siteid=214074 https://www.1sttoyotaparts.com/tollfree.html http://www.toyota-parts.com/ Two of those are local to you, but tell them you are an internet customer for the best deal.
__________________
| Tags |
| 1989, 1990, 4runner, ball, balljoint, campaign, engine, gasket, head, joint, jt3vn, outer, recall, removal, rod, service, special, tie |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| ARB bumper 90-95 4Runner and 89-95 truck | Corey | The Classifieds GraveYard | 13 | 06-30-2006 02:35 PM |
| 89-95 pickup/90-95 4runner white face indiglo guage faces | MorphiasX | 86-95 Trucks & 4Runners | 1 | 06-24-2006 08:54 PM |
| ARB bumper ('89 to 95 truck, '90 to 95 4Runner) | Corey | The Classifieds GraveYard | 1 | 03-27-2006 09:22 AM |
