spark plug help, w/ PICS
Old 01-10-2010, 08:12 AM
HAWAIIANSTYLE's Avatar
my ngk spark plugs in order from left-to-right, 1-5.. #6 missing... i noticed #3 looked liked it wasnt getting much of a spark compared to the rest. looks fairly new still. the last two pics is #1 and #3 at different angles. my 4runner is very sluggish so thats why i pulled the plugs. could it be a clogged #3 fuel injector?...
Old 01-10-2010, 08:16 AM
YodaPala's Avatar
No boom boom for that one
Old 01-10-2010, 09:11 AM
sb5walker's Avatar
#3 almost certainly clogged injector (could be bad connection or bad injector).
#4 looks a bit rusty - how's your coolant? If its rusty, I wonder about the head gasket. It's too bad you don't have that #6 plug. You may want to check the compression.
Old 01-10-2010, 09:32 AM
sb5 thanks for the response,.. i put these plugs on about two months ago. then about a month ago i did a compression check and cylinders 2 and 4 were leaking with coolant in the way. so i did a complete head gasket rebuild with the heads machined and valve job. i did however put back the spark plugs since they were still new at the time. cant remember the last time i serviced the fuel injectors, all i did to it was put new o-rings on them. compression is very good all across. #6 plug looked okay just broke in half as i was pulling it out so thats why its not in the pic. sounds very good at idle. it doesnt run rough or shaky at all... more like a throbbing/sluggish feel as im holding the pedal at a steady speed. yeah im thinking its a clogged injector?
Old 01-10-2010, 09:35 AM
also the #4 plug could be the result of what happened when coolant got to it the first time.
Old 01-10-2010, 09:44 AM
sb5walker's Avatar
Check to see if there's an obvious problem with the connector, check the resistance on the injector. If those both check out, maybe buying a remanned injector would be the easiest - Beck/Arnley is $30 on rockauto
http://www.rockauto.com/catalog/x,ca...,parttype,6224
Or send 'em all to witchhunter.
Or buy a remanned set:
http://cgi.ebay.com/ebaymotors/ws/eB...m=280448595642
Old 01-10-2010, 09:52 AM
rangerruck's Avatar
i'm not sure, but here is a good spark plug link;
http://www.autohausaz.com/html/spark...lug-wires.html
Old 01-10-2010, 09:59 AM
1990yota-pickup's Avatar
i would throw in a new fuel filter and new injectors all the way around so there is no doubt in your mind...
Old 01-10-2010, 10:10 AM
thanks.. connector and resistance all good... im probably gonna do that and order some from ebay and replace them all and then send my old ones to get serviced.
Old 01-10-2010, 10:11 AM
fuel filter, fuel, pump, fpr, and cor are all new
Old 01-10-2010, 10:19 AM
well take your old ones to get serviced and then store them in your glove box, along with a set of injector o-rings in case you run it to a jam down the road.. (nothinng like fixxing a problem on the road with cars whipping by at 70 mph )
justdifferentials
Just Differentials
06-13-2022 07:40 PM
Ronnyboy
02-11-2016 05:57 PM
old87yota
10-25-2015 02:15 PM
FRANCOARMANI
10-09-2015 01:27 PM
bobjohnson2121
09-17-2015 08:07 AM
Quick Reply: spark plug help, w/ PICS
