Spark Plug Change/Nut Size 22re??
Stupid question, but this will be my first spark plug change on this engine. What else besides wires and plugs should I change out? Good running truck, never any troubles just wanting to do preventative maintenance. Also, what size deep socket to pull the plug out with? Thanks, from a diesel guy with little gas engine knowledge.
You might want to include a cap and rotor .
You might want to use a spark plug socket 13/16"
Air filter he if you don`t change it with the oil.
might want some never seize for the plugs Dielectric grease for the spark plug wires.
For what it is worth I had miss issues till I started using Toyota wires.
Yeah cool ok, that's like pulling the motor out just to change the injectors. Hopefully the timing won't be an issue. I bought the truck a year ago now, haven't touched anything but oil changes, air filter, and brakes.Oh , and a few days ago my A/C belt loosed up from running A/C all day driving 85+ on a highway trip. But also only put about 10k on it in 1 year.
Ok went with Borg-Warner wires and NGK plugs from O'Reilly. Old plugs were a different grade NGK btw..#3 and #4 plugs were totally corroded, amazing the truck still ran. Also did the fuel filter today as well. We'll see if the mileage improves now. Truck has a little more pep now.
88runnergomas
07-09-2015 01:12 PM
