Spare tire carrier..Pickup
Just wondering what you guys have done or built for carrying your oversized spare tires? Thanks..(1st time poster)
i just got 31s, so i just keep my spare where the stocker goes. ive held up to a 33 under there before with no issue. its weird though, when i went to test it after 4 years of it not being touched, it cranked as if i had been oiling it and running it all the time. so weird.
Ozzie you are probebly the only one in the world that has a working spare tire winch. What a piece of crap. I have cut mine out of every Toy truck I have owned (3).
If you just want one that sits on the inside side of the bed there is one available, I've seen it in stores it is just a piece of L shaped bent metal with a bolt braket to secure the tire that you bolt or rivet to the pickup box, not very pretty but functional. Can't remember the name but I think the company was out in Indiana or Iowa. I'll try to find it again for you...
My spare is a 35 to match the others, so I couldnt mount it under the bed. I had it sitting flat in the bed for a few years before I got tired of cleaning out all the crap that collects underneath it. I made this out of 1 3/4" tubing and some rectangle tubing that I had found. I made it so that if I pulled out the pins closest to the cab it would sit flat (so I could put my dirt bike in the back w/o removing the spare) I like the extra room that it freed up and now my spare is secure from theft.
I made the pins out of some wing nuts and some round stock that I welded together because I couldnt find any of those quick release pins in the right length at the time, and since then I have been to lazy/cheap to find the right ones.
To mount the tire, I used all thread through the middle of the center rectangular piece - after I sleeved it. I used a nut on each side of the rectangular piece to keep it in place. I welded the nut that faces down to keep it from backing off. Then I cut a piece of diamond plate round to hold down the tire and welded a nut inside of that. I drilled out the all thread on the tip to add a lock.
mr_manny
07-31-2015 10:39 AM
skoti89
07-08-2015 12:05 AM
