Someone PLEASE HELP.. solenoid problem...
Here's my problem...
I am wondering which color (black,white,or yellow) wire goes to the No. 2 solenoid in the transmission. BTW 1994 V6 AT 4wd 4runner. thanks a million, Lyle
One person says its the black wire, while another person says its the yellow wire.
Which one is it, please help, its cold out, and I'm tired of walking around this town....
Here's a reference to the same diagram you posted but it has the colors labeled:
didnt.doit.wisc.edu/offroad/Toyota/manuals/ileaf/95toyrm/95toypdf/95rmsour/1995/954runne/at2/valvebod.pdf
I don't know if this will give you what you need or not -- it doesn't identify which solenoid is which, just identifies which colored wires go where.
It appears in the FSM that the wire from the ECU to the #2 solenoid is black. Which wire that connects to inside the transmission, I'm not sure. Can you tell by inspecting the connectors?
I apologize for misinterpreting your original questiion -- I thought you were asking about the vehicle wiring harness wire color -- which the FSM seems to identify.
This wiring diagram shows 2 wires going to the #2 solenoid. http://www.ncttora.com/fsm/1990-1995...stemci/ect.pdf
It looks like to me one is solid black and one is red with a white stripe, but I'm not very good at reading EWDs.
Longbed 90
10-19-2015 11:05 AM
