Someone help me with my TPS adjustment
Old 03-06-2009, 09:09 PM
91Toyota's Avatar
I've been trying to figure this out for a long time and I am really frustrated.
Anyway, I can't get anything in spec. I just bought a $40 used tps w/a plug and still can't get that into spec. I've been sitting here for a couple hours trying to figure out what the heck i'm doing wrong.
The tps's are completely different too.
This is my throttle body and this is the new (used) tps
The top is the old and the bottom is the new one I just got
Why are they so different?????????
This is off of my 86
Old 03-06-2009, 09:24 PM
OutlawMike's Avatar
I have a 3.0, so, could not comment on the differences between those two parts. Are they both factory Toyota TPS's?
As for the adjustment, could you describe a bit more what is happening? Which resistance measurement are you have trouble with? How many do you get in and which one makes the other or others fall back out?
Mike
Old 03-06-2009, 10:11 PM
91Toyota's Avatar
Mike
Okay,
OLD/NEW
First test on both...(both same multimeter at 20k ohms)
0.70 and 0.02
Second test (both at 200 ohms)
infinite and 9.6
Third test (both at 200 ohms)
Infinite and 18
Fourth test (old at 20k/new at 2000)
5.07 and 1106
Fifth test (both at 20k ohms)
5.68 and 6.15
So, is that in spec???
http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
Old 03-07-2009, 09:22 AM
91Toyota's Avatar
bump...need help!
Old 03-07-2009, 09:31 AM
Flash319's Avatar
You have the wrong TPS. There are 2 different ones, pre-89 and post 89.
Old 03-07-2009, 09:48 AM
91Toyota's Avatar
And I need the post 89 one because my truck is an 86???
Old 03-07-2009, 10:16 AM
Flash319's Avatar
Maybe it is not date specific but there are 2 different ones. My 88 was different then my 89, 92, 93 and 95. The tabs are 90 degrees like your picture show. You should not have to turn the TPS to install it. It should just slide on.
Someone may have changed the engine, or throttle body at some point. The electrical plugs are the same though so the TB can be interchanged.
zytra
01-24-2019 03:16 PM
ZGjethro
06-07-2017 11:04 PM
the_supernerd
10-01-2015 09:20 PM
Rerun
3.4 Swaps
10-01-2015 12:24 PM
dbollier123
09-29-2015 05:23 PM
Quick Reply: Someone help me with my TPS adjustment
