Some pointers on installing BJ Spacers?
Hello,
I will be putting my bj spacers on tommorow and was wondering if anybody had some pointers on installing them, to make my life easier.
I will rent a bj seperator tommorow from autozone.
just wondering if anybody had some trouble installing them?
thank you
thank you
the only thing we had to do was unbolt the upper BJ from the upper A-Arm and cut the back of the A-arm. http://4crawler.com/4x4/ForSale/Docs...er_HowTo.shtml
yeah thats all you gotta do. the studs can be a pain to knock out if you dont spray them a bunch...but other than that just make sure you don't overextend the cv's or else it can be a pain to get everything lined up again.
I used a large socket between the upper A arm and the upper bump stop when the suspension was compressed... then jacked it up, unbolted upper ball joint and the lowers fell down left plenty of room for grinding.
You dont need the BJ seperator
I just installed mine last weekend and all I can say is make sure you compress your Tbar as much as you can. Then put a 2x4 ir somthing in the upper bump stop to keep it up there. I did not make mine high enough and it was a pain in the ass.
Good luck,
Jeremy
Good luck,
Jeremy
Here's mine.Im running 33 x 12.5 on 10" MT rims.1" body,diff drop and stabilizer drop.lift shackles in the rear.I slacked the torsion bars, removed the shock and the steering stabilizer. I installed a pair of Pro-Comp shocks that is longer than Ranchos that came with the truck.
09-04-2015 09:27 AM
WellsR
12
07-31-2015 03:27 PM
terminator
07-27-2015 07:13 PM
