Solid or Crush pinion spacer?
I tore out my rear third member to replace my pinion seal after an outing and since then i added new bearing and an aussie locker. I added new bearings because of 300,000 miles of use even though they looked beautiful, with not pitting or scratches, the aussie was needed since i get stuck to often when i wheel with bigger rigs.
Anyone know where to get a solid spacer for less the 32.99?
Trail-gear sells them for $19
http://trail-gear.com/toy-diff-setup.html
If you replaced the bearings, you'll wanna check the gear pattern, could have changed and you might need to shim the pinion... worth checking.
solid spacers just take a bit more time to install to set the bearing preload but once it's set you dont gotta worry about it
Alright thats a hell of a lot cheaper than at JustDifferentials, and yea i would like to not have to worry about the crush sleeve again. Thanks guys
ashamsuddin
17
01-13-2023 03:17 AM
kawazx636
10-06-2021 03:03 PM
FS[MidWest]: 1.5" ball joint spacers
4x4YOTA
08-23-2016 09:08 AM
FS[SouthCent]: TX - 4Crawler Ball Joint spacers
crash813
09-27-2015 07:15 AM
Odin
09-26-2015 06:56 PM
