So, who has replaced the front universal joint?
Where the front drive shaft connects with the T- case is really loose. The U-joint looks like the cause. Is it difficult? I'v been told it's difficult.
It can be difficult. Some say use a cutting wheel and cut each section out and it's a breeze then. New one goes in much easier than old came out. Make some match marks to keep drive shaft aligned and also note position/side grease fitting on and which direction it's pointed (grease fitting).
I tried to knock mine out and never could get it, cut off the sections and it knocked right out. Makes sense, since you would be knocking one cup out at a time.
there is actually a tool for u joints - its like a big c clamp you use with an impact gun. very cool tool...one of my favs. does ball joints too. cutting and hammering them does get the job done just the same though.
WTB[WestCanada]: 1989 4runner stock front bumper and other items
lledwod
08-30-2016 01:03 PM
Vargntucson
07-04-2015 12:15 PM
