So what sort of axles should I be looking at for 400whp
Old 04-10-2009, 11:23 PM
annoyingrob's Avatar
As usual, I can't just leave my vehicles stock. I've settled on a 400whp build for the truck. Engine, transmission, and transfer case have been chosen, but I'm on the fence regarding front and rear-ends.
I've heard a lot of talk of beople shattering ring gears when they atart pushing some serious power on these trucks. The MKIII Supra guys run 400whp and more through their 8" rear-end with no problems. Even the MKII guys pump some pretty decent power into the 7.5", so what is it about the truck that makes them so weak?
Let's assume for a minute that I leave the front-end alone, and want to run it in 2wd with a bunch of power. I've settled on an autolocker in the back (for the snow). Gear sets have yet to be chosen, but strength is going to be the first choice, then tire size will be determined after that. Anybody have any input?
Old 04-11-2009, 01:02 AM
Matt16's Avatar
I'm guessing the guys who shatter gears are running too much backlash (ie: .015"). Spec is .007" IIRC. Over time, backlash seems to increase, at least, that's been my observation on old diffs- they end up with .011+. Also, bearing preload goes and then the ring gear can deflect away from the pinion and further increase the backlash under load. With the load really shallow, teeth chip.
Now, where are you going to get 400rwhp? Those Supra motors are probably getting their 400whp at 6000rpm- hardly very useful on a truck.
I would look for high torque instead of horsepower.
400whp and an auto locker on snow... that's going to be fun in Calgary for 4 months of the year.
Old 04-11-2009, 08:25 AM
RobD's Avatar
You mean 4 weeks.
Old 04-11-2009, 02:13 PM
desert-rat660's Avatar
who needs horsepower and torque when u got gearing to play with.
Old 04-11-2009, 02:18 PM
iamsuperbleeder's Avatar
well I have a feeling that he's going for 400 HP for a reason other than slow crawling
but yeah I'm kinda curious what you're going to be pushing 400 HP out of? what motor?
Old 04-11-2009, 02:19 PM
T-1000's Avatar
I'm going to put a 1UZ in my truck, I've been trying to find an Landcruiser 9.5" diff to put in a Diamond axle, but those things are dang near impossible to find.
Old 04-11-2009, 02:22 PM
go with rockwells
Old 04-11-2009, 02:26 PM
I'd say just put a Ford 9" under it and call it a day
camo31_10.50's Avatar
how about a dana 60 front..then a corp 14 bolt rear?...
theres guys around here that push 600hp through stock dana 44's...so a dana 60 should hold 400hp..
if thats not your cup of tea...go with 2 1/2ton rockwells..you cant break them..haha
Old 04-11-2009, 11:33 PM
A dana 60 up front might not be out of the question. I kind of like the whole ford 9" idea in the rear.
Motor is to remain under wraps until it's complete. The reason for the build is just because. The power isn't for the snow, the power is just for the sake of having the power. Being used to driving a 500+whp car makes me want a little more power when I drive the truck.
Old 04-12-2009, 12:25 AM
Fossilized
Staff
dropzone's Avatar
How many Supras have you seen with 33"+ size tires on them? Smaller tires probably help reduce the strain on parts
Put a Spyder Trax 9 Axle in the back, it should do nicely. You can order the tubes to match the stock Toyota. Or a Currie Custom Axle
the only limiting factor is your fab skills and wallet.
Old 04-12-2009, 02:02 AM
Audrey3's Avatar
Old 04-12-2009, 05:50 AM
waskillywabbit's Avatar
D60 F
14bolt R
Rockwells are just too heavy to do anything with. Takes a cherry picker to move the dang diff.
Old 04-12-2009, 06:17 AM
Banned 'cause I was 4runnerchevy also banned
86toylet's Avatar
Originally Posted by waskillywabbit
D60 F
14bolt R
x2 on the 60/14
Old 04-12-2009, 10:48 AM
Jay351's Avatar
Why bother? The yota 8" is comprable to the ford 9" in strength.
I have seen toyota axles survive with all sorts of v8/high powered powerplants under the hood.
Get a v6 rear end and upgrade the axle shafts. Good time to swap in rear disc brakes too!
Old 04-12-2009, 10:49 AM
mattaway's Avatar
i seen a guy with rockwells on an f250 with 44" boggers snap something in the front end. it wasn't a pretty site. i wish i had my camera that day
Old 04-12-2009, 10:59 AM
Alex 400's Avatar
yeah the 16 spline shafts in the deuce and a half axles are brittle. for reference, the deuce and a half motor only makes 150-180 horsepower and 400-450 ft pounds of torque. so combined with a high horsepower diesel or big block, 6:72:1 gears and what ever tires you are running on it, you have a better shot at breaking things. there is a guy that is making full 2" axle shafts and lockers for the 2.5 ton axle. makes them way stronger.
http://www.ouversonengineering.com/axle_products
Old 04-12-2009, 11:05 AM
i've seen ford 9" rear ends withstand 800-1000 hp on drag cars...comparable to a toyota?..dont think so..
hes talking about 400whp..how would a toyota axle withstand that..when i've seen them bust with a STOCK 350!
i still say dana 60 in the front..then corp 14 in the rear..i've seen them hold well over 1000 hp on mud drags..lol
Old 04-12-2009, 12:18 PM
Jay351's Avatar
I have seen plenty of v8 toyota with stock rear ends. They rip it up but I have never seen them break a rear end. Depends what you're doing with the truck I guess.... Stock 350 breaking a yota axle? thats weak.
Old 04-12-2009, 12:22 PM
maybe it was like mine, with nearly 300k on the stock (and abused) driveline
Quick Reply: So what sort of axles should I be looking at for 400whp
