So I need a new(er) OE idler arm...
The shaft diameter at the lower idler arm bushing has been reduced by corrosion and wear. Its probably 1/16" smaller in diameter than the top of the shaft.
Is there any point to getting an idler arm from a wrecker, or are they all going to look like that after 13-22 years?
i would say stay away from used idler arms. the bushings in mine went bad but i just said F it. instead of buying $5 replacement bushings i bought a new one from napa for $75.
it also depends on which part of the country you live in. I'm in cali and i have virtually no rust/corrosion on any of my interior/exterior
if you buy a used one... i think it would be pretty hard to tell if the ball joint were bad by just wiggling it in your hand
sheez, i should probably get one of those too.
i got mine from the junkyard...wasnt wasting money on a new one when a SAS is in the near future for me
but then again i lucked out n found a 4runner with a blown 3.0 in the boneyard with a "new" greaseable idler are/ pitman arm and new steering box (receipts in the glove box said they were 6months old
Longbed 90
03-11-2019 12:38 PM
