Snapped cv shaft end
Old 04-09-2016, 12:29 PM
irv
irv's Avatar
I recently aquired n 86 4wd pickup in pretty good shape. Only major issue was that the front right wheel's camber looked horrible and bearings felt beyond shot. Lots of play in the wheel when jacked off the ground. When I opened things up this is what I found. If I buy a new CV half shaft, will it provide me with everything I need to replace this? What about that little mangled brass looking thing? Any seals I need? I'm also doing both wheel bearings and bought the marling crawler kit.
Old 04-09-2016, 04:47 PM
Fossilized
Staff
dropzone's Avatar
If you buy a cv axle you generally get the CV axle.
Any reputable parts place can get the misc parts
Old 04-09-2016, 06:53 PM
MudHippy's Avatar
Wow! That's some pretty sweet carnage. I've never seen one break there before.
CV axle seals and bushings eh? Well...that's where it gets a little tricky. But we've got a thread for that. So you could be in worse shape.
https://www.yotatech.com/forums/f116...rt-earn-96581/
Old 04-09-2016, 10:53 PM
irv
irv's Avatar
Is the mangled brass looking piece in my picture an axle bushing?
Old 04-10-2016, 03:41 AM
Andy A's Avatar
Otherwise known as the Outer steering knuckle bushing.
Old 04-10-2016, 08:28 AM
irv
irv's Avatar
Excellent thanks for the info. I've been doing a bunch of research and am finding conflicting info. Are there two brass bushings per side on the IFS trucks? An inner bushing and outer bushing? Do the brass bushings from 1985 and prior solid axle trucks fit the IFS trucks? What product should I use to lubricate them before installing the new CV halfshaft? If anyone has any answers it would be of tremendous help to me! Thanks!
Old 04-10-2016, 09:03 AM
irv
irv's Avatar
I have come across this which is expensive: http://www.lceperformance.com/1986-1...-p/1054128.htm
And also this, but which only pictures one bushing. From the picture it looks like it's the inner bushing and seal. If I could just find the outer bushing then this would be the best bet on price.
Amazon.com: 9038130003 - Oil Seal Kit For Front Axle Overhaul For Toyota: Automotive Amazon.com: 9038130003 - Oil Seal Kit For Front Axle Overhaul For Toyota: Automotive
Old 04-10-2016, 09:45 AM
MudHippy's Avatar
The pic below shows the outer bushing and the outer seal. The inner seal is on the CV axle.
The inner bushing is shown on the bottom of the same page.
Old 04-10-2016, 11:51 AM
irv
irv's Avatar
Nice! I had missed that. Appreciate that!
Old 04-11-2016, 01:55 AM
Andy A's Avatar
Would be nice to know what actually caused that carnage since it seems very
unusual.
Old 04-11-2016, 02:04 AM
irv
irv's Avatar
unusual.
I think it was caused by driving on completely shot wheel bearings. The wheel bearings were literally disintegrated. Nearly nothing left of them. There was so much play in the tire/wheel it felt like it was about to fall off. I think the total lack of support put too much strain on the end of the shaft and it snapped.
Old 04-20-2016, 08:39 AM
irv
irv's Avatar
So I've bought all new wheel bearings, brass bushings, cv shafts and seals. The smallest rubber seal, orange colored seal and the seal directly above the orange colored seal all came in the Marlin Crawler wheel bearing kit. But I don't see a spot on my truck for either the small rubber seal or orange seal. They don't seem to exist on my truck unless I'm somehow overlooking them. The large seal in the picture directly above the smallest rubber seal came with the brass bushings and I clearly see a home for it on the truck. But as far as the other two, I can't figure out why I have them. I'm only seeing installation spots for two of these four seals on my truck. 4x4 1986. What gives?
Also, does anyone have a part number or name for this large seal? It is from behind the rotor, attached to the steering knuckle.
Old 04-20-2016, 12:50 PM
MudHippy's Avatar
I don't know about the first question. But the answer to the last question is Type K Oil Seal 90313-93002.
wolfpackfan33
03-03-2016 04:39 PM
Kevslatvin
02-23-2016 04:44 PM
jsindorf
02-21-2016 09:41 AM
4.34runner88
02-21-2016 04:23 AM
Remme
02-02-2016 09:23 AM
Quick Reply: Snapped cv shaft end
