*SNAP* Rear Axle sheared off at 45mph and tire went for a ride! - Page 3 - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 04-16-2007, 12:10 PM   #51 (permalink)
Brenjen's Avatar
Quote:
Originally Posted by drew303 View Post
The axles DO have a C-clip.
edit.
The clip is at the end of the axle, not in the differential. You press the bearing on the axle far enough down to where a C-clip slids on into a groove that prevents the bearing from "un-pressing" itself. The only thing holding that axle onto the truck is the bearing on the axle and the bearing inside the bearing case which is held to the axle by 4 bolts. The clip keeps the axle from moving perpendicular to the bearing.
I'm used to GM & Chrysler rear ends, I've never had a Toyota apart. I read the page Mudhippy linked to in this thread & it was informative but sadly not Toyota specific (I'm slow, sue me) the C-clip I'm talking about is obviously not the same retainer you're talking about. A pressed on bearing that has the kind of C-clip I'm referring to would be useless as tits on a boar, it would need something spring loaded for tension...like an internal circlip or snap ring. Maybe I just can't picture how Toyota has their rears designed because I can't see how the C-clip I'm talking about would be of any use at all in conjunction with a pressed on bearing. I have a serious urge to go to the junkyard & tear one apart now.
__________________
'95 4Runner 3.0 Automatic bone stock; it's becoming a project slowly but surely, one part at a time
"If ye love wealth better than liberty, the tranquility of servitude than the animated contest of freedom, go from us in peace. We ask not your counsels or arms. Crouch down and lick the hands which feed you. May your chains sit lightly upon you, and may posterity forget that you were our countrymen!”
Brenjen is offline
Old 04-16-2007, 02:07 PM   #52 (permalink)
gonzo's Avatar
Send a message via Yahoo to gonzo
Here is the pic your looking I think.
__________________
88 Toyota pu 4x4 22re 5spd. 4:88's, 2-1/2" exhaust from cat back, 3" BL. 33x12.5 thornbirds for play, 35 conti-trac for everyday. 10K winch. Pioneer with 4" kenwoods in front, 6-1/2 MTX's in rear on a 600W amp and 12" sub on a kenwood 120W amp. 600w power inverter.
91 Toyota pu 4.3 Vortec 5spd.
gonzo is offline
Old 04-16-2007, 02:14 PM   #53 (permalink)
SteveO's Avatar
Send a message via Yahoo to SteveO
Hmmm, I don't know if that is the case for the 3rd gen 4Runners and Tacos. I'll have to check my manuals tonight when I get home for this type of clip.
SteveO is offline
Old 04-16-2007, 02:26 PM   #54 (permalink)
gonzo's Avatar
I thought this was a 93 4runner that happened to and this was started about.
3rd gen. prolly is different don't know.
__________________
gonzo is offline
Old 04-16-2007, 02:40 PM   #55 (permalink)
RunnerUp's Avatar
this is on my 3rd gen when i had to replace my bearing, now im scared and want to take my truck to toyota to have them double check everything!!!
__________________
Kyle
2002 4Runner - Lifted/Locked/Armored/Charged - 145k Miles
2007 4Runner V8 Sport Edition 4WD 20k Miles
Buy My Stuff!!!
http://www.yotatech.com/f109/97-4run...rt-out-151470/
RunnerUp is offline
Old 04-16-2007, 02:40 PM   #56 (permalink)
RunnerUp's Avatar
sorry they arent the best pics of what you wanted, but its as close as i could get!
full thread here
http://www.yotatech.com/showthread.php?t=110243
__________________
Kyle
Buy My Stuff!!!
RunnerUp is offline
Old 04-16-2007, 03:05 PM   #57 (permalink)
tc
tc's Avatar
Yes, it's a '93, but I think the rear axle is the same. I didn't really look at mine close when I pulled them to do the ARB's, so I'm not sure, but wouldn't there have to be a groove or something in the axle shaft for it to hold to?
WTF is that gear thing in the pix above? ABS resolver?
To make a long post a little longer - I don't trust a press fit like I do a solid mechanical connection like a FF axle has.
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks!
Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R
96 Impala SS: My own personal cop car
Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place
Stop with the mods and get on the trail!
Pix at www.4wheelingoh.shutterfly.com/action
tc is offline
Old 04-16-2007, 04:00 PM   #58 (permalink)
RunnerUp's Avatar
there is a C clip that holds it together, and the bearing and restraining rings are are all pressed until they wont go any farther.
the gear thing is an abs exciter ring that they have to cut off (along with both reatainer rings 92$) in order to press the bearing on. the guy i took it to here in gainesville was referred by gatorland toyota, so hopefully he knew what he was doing!
to be honest with you, this was the first time i did this (bearings were replaced at 80k and i currently have 117k) and after seeing how it was set up, i dont know how much i trust it. dont even get me started on 4 tiny bolts holding my axle shaft to the axle housing thing... though i guess it has been fine for everybody else, so maybe i shouldnt worry abt it.
on a side note, both front axle seals are leaking so i need to find some info on how to replace those and get to that...
i love the smell of 75W/90
__________________
Kyle
Buy My Stuff!!!
RunnerUp is offline
Old 04-16-2007, 05:01 PM   #59 (permalink)
Brenjen's Avatar
Quote:
If that is what you folks are referring to; that's not the C-clip that is being talked about (by me at least). That is a spring steel circlip or snap ring if you prefer. The C-clips I & others are talking about are not spring steel & do not require snap ring pliers to remove. I'm sure that's where the confusion is coming from, the Toyota has snap ring retainers, not C-clips. The C-clips we are referring to are named that because they look like a "C" it's not short for circlip.
Edit: thanks for the picture Gonzo!
__________________
Brenjen is offline
Old 04-16-2007, 05:23 PM   #60 (permalink)
RunnerUp's Avatar
brenjen your right, it is called a snap ring by toyota and most other people. guess i just followed the pack on that one...
__________________
Kyle
Buy My Stuff!!!
RunnerUp is offline
Old 04-16-2007, 05:28 PM   #61 (permalink)
CLEANSR5's Avatar
jeez, sorry to hear, glad you are ok though.
__________________
1997 Runner SR5
3" SL, 2" BL, 285 BFG M/T's, Deckplated, Lake Tahoe Tamer
-Phil
CLEANSR5 is offline
Old 04-16-2007, 08:02 PM   #62 (permalink)
Staff
Lysmachia's Avatar
Send a message via AIM to Lysmachia Send a message via MSN to Lysmachia Send a message via Yahoo to Lysmachia
Quote:
Originally Posted by Brenjen View Post
Sorry about your luck by the way, glad no one was injured. Also; it might not be the previous owners fault, sometimes things just break.
I don't think it was the previous owners fault. He is a Toyota Tech and knows his stuff... I think I just wheeled the crap out of tippy and it finally gave.
I won;t know what really happened till Thursday when All Phase and I tear into the axle and 3rd member to see what's going on. I will definitely let you all know and document with pictures too...
Thanks everyone for your input!
__________________
Molly
aka Lysmachia
93 4 Runner SAS (Tippy) - All Broken in Junk Yard Goodness
Get your 4x4 VIDEO pr0n here
Quote:
Originally Posted by leebee View Post
from this gray haired old red head to you, EGO BOOST!! you go girl!
Lysmachia is offline
Old 04-16-2007, 08:06 PM   #63 (permalink)
gonzo's Avatar
How about a pic of the axle at the wheel end, where the bearing would be.
__________________
gonzo is offline
Old 04-16-2007, 08:13 PM   #64 (permalink)
drew303's Avatar
sorry for referring to it as a C-clip =/ i guess we were all the on the same page except for those that are familiar with different axles =p
Im happy you're all ok to, that would be scary!
Maybe im confused, whats a 3rd gen 4runner? Isnt a 93 called a 2nd gen? When did they put ABS on toyotas?
__________________
1987 Pickup, single cab, 22R, new head, 260 cam
TG 3" SAS, rear disc brakes, chromoly rear axles, Chromoly Birfs, Tcase brake, 37x12.50R15 MT/Rs, 5.29 gears, rear Aussie Locker, front Detroit Truetrac.
drew303 is offline
Old 04-16-2007, 08:49 PM   #65 (permalink)
tc
tc's Avatar
Second gens have rear ABS, but the sensor is in the diff.
__________________
tc is offline
Old 04-16-2007, 08:53 PM   #66 (permalink)
Staff
DeathCougar's Avatar
Send a message via AIM to DeathCougar Send a message via Yahoo to DeathCougar
Quote:
Not always true.
Some 2nd gens have 4 wheel ABS, where there are sensors at each wheel. PRetty sure this didn't start until 92 though. Either way, not ALL 2nd gens are 2 Wheel ABS with the sensor in the diff.
__________________
Tacoma miniheader install kit Now available! Click here for ordering information
Need that hard to find part? Nix99 Used Toyota and Lexus parts!
Quote:
Originally Posted by space-junk View Post
DeathCougar, you know everything!
Quote:
Originally Posted by fustercluck View Post
Now I know DC is a leader.
DeathCougar is offline
Old 04-16-2007, 08:55 PM   #67 (permalink)
tc
tc's Avatar
News to me - I thought the 2wheel ABS was even optional, the 4 wheel must be super optional
__________________
tc is offline
Old 04-16-2007, 09:08 PM   #68 (permalink)
Staff
2 wheel ABS was technically optional, but its sorta like power windows on most 2nd, and 3rd gen 4Runners.....almost all of them had it. 4wheel ABS was usually for the "Limited" style 94 and 95 4Runners.
__________________
Old 04-16-2007, 09:28 PM   #69 (permalink)
80W90's Avatar
Quote:
Originally Posted by SteveO View Post
Are you talking about a domestic axle, such as a D44 axle? I know those type of setups use a C-clip on the inside of the axle. I was not aware of Toyota's using a C-clip on the inside of the axle. With Toyota having a 3rd member that drops out, how would you get the C-clip onto the inside of the axle?
Domestic innards of the diff:
*snip*
Another image of the inner axle shaft on a domestic or C-clip type axle shaft:
*snip*
Again, with the drop out 3rd, I don't see how you can place a C-clip on the inside of the axle, when the 3rd member is put in.
Unless, you have some special way.....
edit: There is an article that talks about the Toyota's having Pressed in bearings that hold it all together. The C-clip eliminator, uses pressed in bearings. Toyota, as far as I know, uses pressed in bearings to hold it all together. When the bearing fails, you loose the wheel.
*snip*
With the tremendous side loads being placed on our rigs when wheeling, these bearings are prone to loosen up. When my wife was driving my rig home, I was following her and noted that the driver rear wheel was wobbling a bit. I pulled the shaft and drum, and noted that the bearing had some play in it. I decided right there, it was full-floater time. I have the FROR Full floater kit, and it is awesome! I don't worry about pressed in bearings failing anymore due to a heavy vehicle side loading the bearings. Plus, now my bearings are servicable when I want to service them.
I am talking about thr OEM axle.
They use a clip too, but it is served differently and works in a slightly different manner.
this is the clip im talking about
__________________
1980 4X4 - 1986 4Runner - 1989 4X4 - 1979 4X4 - 1987 4X4 - 1990 4Runner-1994 4Runner-1989 4Runner
22RE 22RE 22RE 22RE
80W90 is offline
Old 04-16-2007, 09:29 PM   #70 (permalink)
80W90's Avatar
Quote:
Originally Posted by Pest View Post
Holy crap, that just seems like something you'd see on some comedy skit, with the wheel flying past the vehicle.
Just while we're on the same topic, is it possible for the front wheels to pop out like that? Or is that just a rear thing with the pressed in bearings?
sure it is. if you dont tighten your wheel bearing nuts, and use the lock washer.
__________________
22RE 22RE 22RE 22RE
80W90 is offline
Old 04-16-2007, 09:32 PM   #71 (permalink)
80W90's Avatar
Just my opinion, but I think at this point, giving your tendancies to push the limits of Tippy, you would be better off going to a Full Floater. Brian at FROR can hook you up with the parts you need to make Tippy into a stronger rig. You may be able to using the existing axle tube, and slap Brian's Full Floater kit on. In the long run, you will definitly be ahead of the game.
its not a matter of tippy is a POS, and need to be upgraded, its a matter of a technician not installing a part correctly.
no need to go to floaters.
__________________
22RE 22RE 22RE 22RE
80W90 is offline
Old 04-16-2007, 09:34 PM   #72 (permalink)
Super Moderator-Sponsoring Member
Staff
waskillywabbit's Avatar
Send a message via AIM to waskillywabbit Send a message via MSN to waskillywabbit Send a message via Yahoo to waskillywabbit
If you are going to wheel...full floater gets you home...semi floater leaves you stranded and/or needing to carry spare rear axles shafts...and you don't have to worry about your rear tires passing your on the trails (or road).
For the price...can't be beat...full floater rocks.
waskillywabbit is offline
Old 04-16-2007, 09:35 PM   #73 (permalink)
80W90's Avatar
Does anybody have a pic of this "C-clip" at the end of the axle? I'm curious to see it.
__________________
22RE 22RE 22RE 22RE
80W90 is offline
Old 04-16-2007, 09:38 PM   #74 (permalink)
80W90's Avatar
[quote=tc;50502507]
Quote:
Originally Posted by Lysmachia View Post
You can see the splines are stripped.
Here's the end of the axle ... I don't see a groove in it!
thats cause it aint like a dana axle.
its Japanese
__________________
22RE 22RE 22RE 22RE
80W90 is offline
Old 04-16-2007, 09:42 PM   #75 (permalink)
80W90's Avatar
same.
__________________
22RE 22RE 22RE 22RE
80W90 is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Driveshaft vibration at 45mph + ASU4runner 95.5-2004 Tacomas & 96-2002 4Runners 14 09-23-2009 10:36 AM
Sheared rear swaybar bolts, Too late for easy out - What should I use? mjwalfredo Tool Time 7 08-09-2007 06:18 AM
Solid axle ride quality, stability, and safety - questions Figit090 General Vehicle Related Topics (Non Year Related) 3 05-27-2007 12:24 AM
2wd rear axle vs. 4wd rear axle (newbie warning) fustercluck 86-95 Trucks & 4Runners 3 08-08-2006 03:05 PM
2009 InternetBrands, Inc.
