snagged a low mile rear diff thats been sitting indoors for 10+ years, anything I....
The title says it all! I snagged a used rear diff that has around 80,000 miles on it that is in really good shape, it was removed over 10 years ago and stored covered on a shelf. Anyway, it feels very smooth and very tight compared to what is left of my 180,000 mile unit that has been singing terribly for the last 50,000 miles! Is there anything that I should do to the "new" 3rd before swapping it in? I was thinking about shooting it with brake cleaner to clean the dust and old lube off then pre-lubing the bearings and slapping it in with fresh fluid. Any fluid recommendations? I run Redline fluids in my MX5 and have never had a problem, my truck has had Mobil 1 gear lube in the rear since the bearings started howling, they really never got much worse so I guess its OK to run .... I guess any good synthetic 80w90 or 75w90 would do the trick... Thanks again! ~Matt
FYI the "new" rear diff is also just a stock 3rd from an 88 V-6 automatic with 4:10's... I wanted to re-gear and go up a tire size but for what I paid for the used 3rd, the type of off roading my truck sees and the fact that re-gearing both ends isnt cheap I just decided to stick with 30" tires and keep it a dog with the stock 4:10's.......... for now
just get a new gasket and slap that puppy in!
lol, if your worried about it, just get some of the gear-mesh paint and put a little on the ring and spin it around to see where the pinion's sitting, but with only 80k on it, she should be in good shap; I'm having no problems (knock on wood) with the stock 4.10's in my 91 with 295k on it
if anything, I would at least replace the axel shaft seals with it, since you have to pull the shafts out to swap 3rd's anyhow
No More Noise :)
I finally got my new to me Ebay 3rd bolted in last night, 2 hours and 2.5 quarts of Lucas gear lube later its all back together and sounds freaking great! I didnt realize just how loud the old rear had become!
Team420
01-12-2021 04:57 PM
Dharris1986
28
04-17-2017 03:34 PM
cchinny
06-25-2015 08:11 PM
