Snafu wiring. Bad news bears.
Old 10-08-2014, 09:52 PM
Kayceecast's Avatar
Alright guys I got an 86 pickup. And this wiring is just a complete mess, I'm in need of some advice because I have had a heck of a week, I bought this truck just for a project and now all my vehicles, all 7 broke down and this is the closest one to being running. I have the starter hot wired basically, straight to battery up to a switch. Now I have to do the same with the coil. Now I never ran into this problem before so unknowingly I ran the coil neg to battery neg, positive to positive. Coil is getting hot. I have no spark tho. Where would you guys recommend running these wires and what gauge should I use. This is driving me nuts. Thanks in advance. The s.n.a.f.u. Wiring problem.
Old 10-08-2014, 11:50 PM
wyoming9's Avatar
Red face
Why is the wiring a complete mess??
Just what is wrong??
If you have no idea what is wrong how can you even start to fix it.
Do you have a 22R or 22REC??
Old 10-09-2014, 01:56 AM
Staff
Terrys87's Avatar
If it is repairable I would go that route, if it is a total disaster, and I have seen that in the past, I would do a wiring swap. https://www.yotatech.com/forums/f116...4-88-a-278925/ You can replace it in sections, depending on which one you need. Injector harness, Main harness, Headlight harness, and tail light/fuel pump harness. You may not need to replace all of it. This is for an EFI system but applies to carb systems for the most part.
Old 10-09-2014, 03:44 AM
Kayceecast's Avatar
Between the rats, and the previous owner it's destroyed. And it's just being turned into a prerunner so I don't care for spending money on some wiring vrs just jerry rigging it cause I have thrown way to much money into it trying to fix this that I'm fed up and just want to hot wire it.
Old 10-09-2014, 03:49 AM
kcaudill's Avatar
Wiring a coil directly to the battery (-) to coil (-) and battery (+) to coil (+) will burn it up. The coil need a trigger to cycle on and off. The believe the ECU for a 22re gives this signal. once the coil cycles on then off it will discharge its voltage to the distributor then to the spark plugs. Its all about the timing.
Old 10-09-2014, 05:13 AM
mct75's Avatar
If the starter motor still works and is connected to the battery positive, you can always manually push the plunger down to start the truck. You'd need to drill a hole in the solenoid cover, maybe a 3/8" drill bit and push on it with a bic pen? It sounds like you may not be the best with wiring so a mechanical approach might be better.
Old 10-09-2014, 06:55 AM
Kayceecast's Avatar
Yeah, wiring is defiantly not my strong point cause I'm almost positive I burnt this coil out. So I guess I'll let you guy know after I get a new one.
Old 10-11-2014, 12:32 AM
RAD4Runner's Avatar
Do it right.
Find schematic
Inspect wiring for condition and exactly where they should go
Decide whether to replace defective wires or replace harness
Old 10-11-2014, 07:58 AM
Fossilized
Staff
dropzone's Avatar
Zip ties, paperclips, pennies and bubble gum....good to go
Old 10-12-2014, 04:15 AM
Staff
Terrys87's Avatar
^^^LOL^^^ I think I just found out how to cut my build cost down. You did leave out scotch tape and it works too. I have seen it.
ghostmoney
01-28-2018 11:42 AM
Blamalam
08-16-2015 12:29 PM
corey519
08-12-2015 11:12 AM
nonstop
7
08-11-2015 09:26 AM
msane99
07-17-2015 10:13 AM
Quick Reply: Snafu wiring. Bad news bears.
