Slower than should be stock 22re
Old 05-03-2014, 10:34 AM
gotduhka's Avatar
Ok so everyone knows the 22re is a dog. But should a 22re 1994 toyota pickup 4.10 gearing 30x9.50 MTs otherwise stock regular cab 4x4 be doing 35mph MAX up 10k' passes? Maybe I'm missing something.
Old 05-03-2014, 11:49 AM
millball's Avatar
What gear you got it in??
My '87 can pull most grades @ 50mph in 4th gear when lightly loaded.
It's got 276, 000 on it. With 31s' and 4.10 this is about 2300-2400 revs.
This seems to be lugging her a bit more than I like, so I often take 3rd gear and run her up around 2700- 3000 revs. Just a tad slower, but the engine likes to run a few hundred higher revs.
Old 05-03-2014, 12:44 PM
gotduhka's Avatar
3rd mostly, 4th isn't an option on climbs
Old 05-03-2014, 03:49 PM
toyota4x4907's Avatar
At 10k feet there is significantly less oxygen/less dense than at sea level, so there is less to use internally per volume... so yes its reasonable going up that your max speed is 35 mph
Old 05-03-2014, 04:25 PM
gotduhka's Avatar
Thanks, I hear other people getting so much more mph up passes but they never say the actual elevation. To be fair, my tires are 50lbs ea. and I was fully loaded with a camper top and a rack on top of that. Silly question now that I think about it. I do need to check my timing though.
Old 05-03-2014, 06:29 PM
wyoming9's Avatar
Red face
Wow you are doing good Mine would be in first gear about 5mph
Old 05-03-2014, 06:41 PM
millball's Avatar
I guess that 8500 is the highest elevation that I have run my truck.
Old 05-03-2014, 06:42 PM
RampartRanger's Avatar
I went up Hoosier pass today in Colorado and it tops out at 12,000ft. My runner made up without little bogging but revving decent in 3rd. If I went to fourth it would bog and I'd have to downshift. I'd say your truck is performing normally.
Old 05-03-2014, 06:59 PM
gotduhka's Avatar
I could do that before switching from 225/75 ATs to 30x9.50 MTs. I will say that the switch only took about 1 mpg away from me and the Cooper STT's preform leaps and bounds beyond my old AT's off road.
This weekend I was cutting Molas and Coalbank Pass in SW Colorado.
RatOmeter
10-22-2015 03:17 PM
1994toyota
07-17-2015 03:03 AM
Nickdigg
07-07-2015 06:04 AM
Jnkml
07-06-2015 01:20 PM
Quick Reply: Slower than should be stock 22re
