Sloppy shifter and shifting
Old 12-10-2008, 07:50 AM
dem0nk1d's Avatar
Is there any way to make out shifting more solid and fluid in movement? (Talking about the shifter it's self.)
Also I think my clutch cylinder needs to be bleed, I’m getting sloppy engagements into gears.
Old 12-10-2008, 07:54 AM
Staff
DeathCougar's Avatar
Your shifter seat has likely disintegrated.
http://www.marlincrawler.com/htm/transmission/6a.htm
see the bottom for new shifter seats
or the top of the page here: http://www.marlincrawler.com/htm/tra...rans_parts.htm
Old 12-10-2008, 08:11 AM
dem0nk1d's Avatar
you can change this part with out dropping the transmission?
Old 12-10-2008, 08:18 AM
allnmstkn313's Avatar
Take off the shifter knobs, remove the shifter boots, and then pull the shifter base out.
Shouldn't take much longer than 20 mins in and out.
Old 12-10-2008, 08:25 AM
TNRabbit's Avatar
Do a search on "shifter bushing" and you should find @ 10,000 threads....
Old 12-10-2008, 10:25 AM
Staff
You don't even need to pull the shifter base off, just leave it bolted up. If the bushing has broken into hundreds of tiny pieces like is very common, you may need to remove the tower to clean all the pieces out.
FWIW, even if you can't clean it all out, thats ok. The shifter seat is soft enough it wont hurt your trans.
Old 12-10-2008, 11:38 AM
Vanman's Avatar
This what I need as well.
I clicked on the correct year/model of vehicle, but I still have a choice. Which ones fit a '91 V6 Runner?
Thanks
I.e. the W56 A or B? Or the "all other"?
Old 12-10-2008, 11:45 AM
Staff
W series trannies are for the 4cyl Truck, so you have "all other" trans type lol. You have an R151F trans.
Call marlin, tell them what you have, and order it on the phone.
Old 12-10-2008, 11:47 AM
bigt's Avatar
would this help grinding into first or rev if i dont go from first to rev first...
just noticed this after my last trail run.. only drive it on off road.. was told the clutch and engine arnt that old.. few years..
manual transmission uses gear oil like the tcase but how do you check the level? or what else should i try bleeding clutch??
only grinds going into first or rev but if i go first to rev it doesnt grind..
punks_is_4x4
02-26-2016 04:29 PM
Davebarbier
11-03-2015 03:28 PM
Flightguy
10-02-2015 05:34 PM
kbpickens
10-02-2015 03:37 PM
creecher10
09-30-2015 03:27 PM
Quick Reply: Sloppy shifter and shifting
