Slooow warm up.
Old 10-05-2009, 02:44 PM
91Toyota's Avatar
Slooow warm up.
My stock 22re truck takes at least twice as long as my brothers stock 22re truck. It seriously took 30-45 minutes to fully heat up in 1st gear.
Anyway, it has a napa thermostat in it. I'm thinking I need to switch it out to the dual-style ones??? Not sure.
Any help is greatly appreciated. Thanks, Trevor
Old 10-05-2009, 03:09 PM
Brad.'s Avatar
Put in a Toyota 190 degree thermostat built for the 22re. They are designed much differently than Napa.
Old 10-05-2009, 03:26 PM
troubled87's Avatar
2nd that, sounds like your napa thermostat is a fail safe that failed in the open position. Saw that once before on a friends tracker. At least it did not fail closed and cause an overheat like mine. Engine Builder here I come!.... when i have the money
Old 10-05-2009, 03:28 PM
toyota4x4907's Avatar
Why would the dual stage ones make it warm-up faster? People buy the dual stage ones to help prevent the temp spike (almost to red) then normal temp while warming up that happens with failing T-stats. Buy a 190-195* OEM one.
Old 10-05-2009, 03:56 PM
troubled87's Avatar
I do not know about the dual stage ones. I am saying I think he has a fail safe thermostat. The last thermostat I bought was supposed to fail in the open position. When it did fail, we pulled it out and it was wide open. With the thermostat wide open it takes FOREVER to heat up because the water is constantly circulating.
Old 10-05-2009, 04:53 PM
BeMiceElf's Avatar
sounds like it is stuck open
Old 10-05-2009, 08:55 PM
91Toyota's Avatar
I've run with a stuck open t-stat before...and with none at all. It never warmed up then.
But now my problem is different...it takes forever to get hot....but climbs and climbs almost to the red then goes down to normal and stays in the same spot.
Old 10-05-2009, 09:20 PM
replace the t-stat.
Old 10-05-2009, 10:48 PM
pruney81's Avatar
get a toyota t-stat, I'm having the temp overshoot issue as well but only on occasion and it has yet to go above half but I'm picking up a new t-stat and gasket from the dealer tomorrow.
Old 10-06-2009, 02:34 PM
pruney81's Avatar
I went to a dealer by my house and they didn't have any dual stages in stock nor did they know anything about it.
So, I just bought a new OEM 190-195* and it seems to work fine.
my truck fluctuates between 1/4 and 1/2 on the temp gauge
Old 10-06-2009, 04:59 PM
peow130's Avatar
I had this problem, then i threw some cardboard infront of the radiator because i didnt want to do any more work on my truck lol
Old 10-06-2009, 08:17 PM
91Toyota's Avatar
Thanks guys...i'll try it and report back.
Old 10-08-2009, 02:11 PM
pruney81's Avatar
I just picked up the dual stage thermostat that I ordered because my truck still ran warm with the stock one. It stays pegged at 1/4 on the temp gauge while running with no heat or heat blasting.
Definitely get the toyota dual stage thermostat you won't be disapointed!
Old 10-08-2009, 02:29 PM
91Toyota's Avatar
Thanks. I will as soon as I pay my $300 tickets off
Old 10-08-2009, 02:36 PM
Kiroshu's Avatar
Oem! Oem! Oem! Oem!
Old 10-08-2009, 03:23 PM
pruney81's Avatar
The thermostat and gasket were 41 bucks at the dealer in Newport RI.
Well worth it for the truck not to be running warm all the time if you ask me
Sleaker
08-26-2020 06:03 AM
1992pickupSr5
05-09-2019 08:44 AM
wafoogalla
11-02-2016 11:02 AM
maddogd
08-09-2015 04:32 AM
tomczaksdiesel
07-26-2015 10:35 PM
Quick Reply: Slooow warm up.
