slipping out of 4WD?
I don't know if this is the correct subsection, but after 3 hours of "getting out" I don't have much of an energy for anything.
I recently purchased a 90 pickup with 3.0 and 4 inch lift plus 2 body and 33's. I think it has manual front lockers (I have to get out and lock them in). I asumed that this is a stock option.
Anyway I took it out this evening and and after a while it began slipping out of 4wheel high or low. I just want to know where I can find some knowledge to narrow down the cause of this i.e. trouble shoot it. My brother said it could be that the front diff is messed up. Any help would be greatly appreciated.
Please forgive my "noobness."
I think you were sold a lemon in need of some dier attention.
The syncros could be bad inside the tranny and could mean entire rebuilt or new tranny is in order. If not tranny... T/C (transfer case) could need rebuilding
Youve come to the right place for help in diagnosing but are you capable to spend the money or do the work as I think your problems are pretty serious and spendy
Another potential cause would be if your vehicle has had manual hubs put on an ADD system and the ADD actuator was disengaging due to a lack of vacuum. If you have ADD, check with this site on how to test: http://toyota.off-road.com/toyota/ar....jsp?id=399612
noobness
I assume it's manual. I have lever on the floor that I shift into 4x4. When it pops out the 4x4 shifter stays in the same place.
noobness
Thank you to everyone that actually tried to help. I guess the rest of you don't have the knowledge base or maturity level to. Plus I am easy target.
Just to clarify it is a manual T.C. being that it's a 90 model.
First I tried the ADD its getting vacuum on both sides of the VSV's.
Next I pulled the manual hubs (Mile Marker). They had way!!! to much grease in them but still that wasn't the problem.
I talked to a guy that said that this really doesn't ever happen in Toyota's. I wonder why its happening in mine.
Next course of action is to drain the T.C. and see whats up in there.
Any other help is very appreciated.
Is the transfer case lever PHYSICALLY moving out of 4wd, like you take off and bang it jumps back to 2wd?
If so, your body lift is causing the body to hit shifter lever or something to that effect. The shifter must be extended and or given a short throw shift so this dont happen.
God darn it. I guess thats what I get. Do you know of any way to check this. What other info do you need to give a good estimation of the problem? I have money it's just that times are hard. humor me how much dose a rebuild cost?
Marlin also sells rebuilt ones
1 Post
welcome to yota tech!!! your one stop shop for all your yota needs
NOw as for your transfer problem i dont think its in the hubs or trany but i do belive its in the a$$ end of your transfercase so to check this drop the rear drive shaft and take that big bolt out jack the trasfer case up just a lil to get the lower mount bolts out and drain the fluid and take all them little bolts out there a 14mm have fun there tight now take that rear output thingy out and take the cover off now ass you can see your gears are not messed right (they dont go tooth to tooth there a lil worn down) and to fix this easy but your self a set of real good gears from wab fab or craller or any place like that cause from what it sounds like is that your in 4x4 and when you put even the smallest amount of torque to it they jump and then it wont work
step two if everything above is fine then its your bearings in your transfercase and the gears are not meshing right
now if its a chain drive then hey your almost done you need to replace your chain guides just like the timing chain and then you should be fine but since you did this a few times and i know the po did this all the time you will need the fallowing
tc chain
tc chain guides
rtv sealet
and your good to go
(dont forget to do the bearings since your there)
gear to gear tc
gears
bearings
rtv sealant
hope it helps and somebody correct me if im wrong on this if you need help i can try and walk you through this man!!!!!
GOOD LUCK!!
tc chain
tc chain guides
rtv sealet
and your good to go
gear to gear tc
gears
bearings
rtv sealant
GOOD LUCK!!
When I am in 4x4h and it slips out it just goes to 2wh (or thats my guess). When I am in L the gear ratio does not change it just loses power to the front two wheels.
Yes, does sound like something going on inside the t-case. If it were just the shifter popping out of gear, you would go from say 4L into neutral as N is next to 4L in the shift pattern. Might try posting the symptoms up on Marlin Crawler's forum and see what the experts have to say:
- http://board.marlincrawler.com/
A buddy of mine was having issues with his case popping out of low range (only) and that was due to some internally worn parts inside the case. Marlin fixed it for him.
But this doesn't sound like your problem...
