Slightly squeaky belt
Old 03-12-2009, 04:59 AM
DupermanDave's Avatar
I have a belt that squeaks just a little bit. It's not loud, but it's annoying when i'm idling.
Does a squeaky belt need to be tightened or loosened? Or does it vary depending on the belt that's squeaking? I believe it's the power steering belt.
Old 03-12-2009, 05:04 AM
Shawsheen's Avatar
mine were loose and needed to be tightened. and that's been the case on many a vehicle.
Old 03-16-2009, 04:53 AM
I know how to tighten the power steering belt, but what about the others? How do you increase tension on those?
Old 03-16-2009, 05:03 AM
Shawsheen's Avatar
IIRC there is a bolt that holds the alternator in place. loosen it, pry the alternator tight with a ratchet extension or something similar. Be careful not to break anything on the alternator or anything else with the 'prying'. It's helpful to have a friend hold the extension and alternator tight while you tighten the bolt.
the other tension bolt is right behind the radiator.
Old 03-16-2009, 05:36 AM
I see. From the pictures, it looks like tightening the alternator is just like adjusting the distributor? There's a single bolt and you just rotate the alternator by loosening that bolt and tighten it when you get it good and tight. Is this correct?
Old 03-16-2009, 06:03 AM
874runnersr5's Avatar
Yup, i need to od mine again. Mine makes a little chirp when starting up.
For mine, i have to get a box end wrench and a ratchet on the other side and loosen with the ratchet and pull with the wrench.
Old 03-16-2009, 06:07 AM
Shawsheen's Avatar
I can't really say because I've thankfully not had to mess with the dizzy.
but it sounds similar.
most manuals give you a spec, I think you want like a quarter inch of play in the belt, or something like that. I just tighten it but don't over tighten it, cause that is bad too. you kinda of get a feel for it after a while.
the other post was correct, not that I think back I used a wrench too, I could not fit the socket in there.
Old 03-16-2009, 06:12 AM
My belts are plenty tight if that's the case. I may loosen them then. Or just buy new belts.
Old 03-16-2009, 10:52 AM
FastLane1000's Avatar
I'm going to introduce myself in another thread when it dries up and I can take some pics of my truck. However, I just got done replacing all the belts on mine and I found the easiest way to get the alternator belt tight was from below. i pulled off the skid plate and from under the truck I could fit a pry bar in between the alternator and block and pry it out with one hand while putting a closed in wrench on the upper bolt. From abover the power steering hoses and stuff were in the way.
fastlane
'88 pickup 22re 4x4 52K miles.
Old 03-16-2009, 11:11 AM
Grrr. I'm tired of the skit plate. I'm constantly removing it to do the simplest things on this truck. Sometimes that's the most difficult part of a job (like changing the oil)
Old 03-16-2009, 11:12 AM
haha, whats wrong with your skid plate??
Old 03-16-2009, 11:37 AM
Tubbyfatty's Avatar
At least you have one....
Old 03-16-2009, 11:45 AM
It's there, that's what's wrong with it, lol.
Nah, the skid plate looks cool and I'm sure it serves a purpose, it's just too much work to remove the 4 bolts and hold the plate up with one arm to put it back in. Especially on the cold ground during winter.
Old 03-16-2009, 01:06 PM
use the hook it has on the botton part ot rest it ontop of the frame bar thingy.
Old 03-16-2009, 01:16 PM
I've used that once, but didn't find much use for it if I was installing it. I still have to hold it up with one arm while I finger tighten all of the proper bolts. It's not that bad, really. I just like complaining, lol.
Old 03-16-2009, 01:25 PM
Haha i hear yea man, mines still been sitting on the side of the garage since i did my timing chain lol.. i just havent gotten to putting it on. yet ive done my leafs, and awhole bunch of other stuff.. i should get on that
Zach_trun
11-17-2015 07:56 AM
mbomberz1
10-09-2015 07:17 PM
mordell
09-12-2015 10:13 AM
larrys93pickup
09-06-2015 06:37 AM
northwalker
09-03-2015 12:21 PM
Quick Reply: Slightly squeaky belt
