slider install?
Old 12-10-2008, 03:45 PM
Junkers88's Avatar
slider install?
When you guys weld your rock sliders onto the frame to you put a piece of plate between the frame and the round tube or just weld the tube to the frame? I'm thinking when I install mine I'd like to do some plating to distribute the stress when the slider encounters a rock.
Ideas?
Old 12-10-2008, 03:53 PM
Scooby098's Avatar
dont they come with those on trail gear ones?
Old 12-10-2008, 04:05 PM
89-4Runner's Avatar
absolutely put a piece of plate in between, and not straight up and down, but diagonally... <>, not []
Old 12-10-2008, 04:19 PM
crolison's Avatar
gusset it with a diamond shaped plate with right angle pieces connecting the gussets and the plate.
Old 12-10-2008, 05:17 PM
space-junk's Avatar
check out dirtco's buildup... hes got pictures of the sliders he put on his runner, and the gussets and frame plates he used...
Old 12-10-2008, 05:25 PM
muddpigg's Avatar
plate and gusset. for sure.
Old 12-10-2008, 06:19 PM
scuba's Avatar
X7 !!!!!
Edit...: Wait, I thought you were trying to sell...That 85 fall through...?
Old 12-10-2008, 07:35 PM
Dan.3's Avatar
just weld the tubes to the frame. Works fine on mine. I have slammed them pretty hard of some rocks and trees and have yet to bend.
Old 12-11-2008, 05:04 AM
Junkers88's Avatar
Originally Posted by scuba
X7 !!!!!
Yeah the 85 quickly got higher in price than I could afford so I'll finish up the little things on my truck and keep an eye out for another SFA 4runner.
Old 12-11-2008, 05:56 AM
mt_goat's Avatar
Here's my slider install:
https://www.yotatech.com/forums/f31/...nstall-100157/
Old 12-11-2008, 08:28 AM
GSGALLANT's Avatar
Although this might still be "working for you", it is not generally the accepted way of mounting sliders. The steel that makes up your frame is not thick.
94ofCanada
08-14-2015 06:37 AM
nickbeauregard
12
08-07-2015 06:04 AM
priest16
15
08-06-2015 07:43 AM
Luvmeye22re
08-04-2015 03:53 PM
coryc85
07-06-2015 04:07 AM
Quick Reply: slider install?
