sleeping platform finished! many pix - Page 2 - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 04-19-2006, 07:17 PM   #26 (permalink)
van7559's Avatar
How many times, what and where did you secure it to the bed?
__________________
1994 Pickup- 22re w/ 70k original miles as of 10/10/05
All Pro front winch bumper, Marlin rear bumper, Marlin sliders, 31" Bfg m/t, K&n filter.
van7559 is offline
Old 04-19-2006, 08:28 PM   #27 (permalink)
photoleif's Avatar
Send a message via AIM to photoleif
i have it bolted to the bed in front and rear, total of four holes. you can see one of the 4" brackets in the bed in the first three pix, with #2 probably the clearest illustration. that mount was easy because i had no obstructions -- just lowered the spare, reached and grunted a bit, and it was in. the other mount, which is in the same place but far fore, wasn't too pretty. turns out i measured about 1/2" wrong and the holes went in right next to the transverse support strap, so i had to put the bolts in at a bit of an angle to avoid that. grrr. it's plenty tight with those two -- not going anywhere at all. i ought to fill the holes with silicone, but at least initially i've got garden-hose gaskets compressed against the holes with the washers, then a lock-washer, then the nut. it's not beautiful but it'll do until i get around to squirting some silicone up there.
__________________
'95 Xtra cab 3VZE SR5V6 | 33x10.50-15 BFG AT/KOs | 4" Superlift | OME torsion bars | Total Chaos idler arm and uniball | Rancho steering stabilizer | Smittybilt front & rear tubular bumpers | Sportsman topper | Aisin hubs | Dual Optimas | Extended diff breathers | Custom center console
sometime: rear locker
some sometime: retire the IFS
My truck page
Photography:
http://www.aspen-graphics.com
photoleif is offline
Old 06-01-2006, 08:21 PM   #28 (permalink)
photoleif's Avatar
followup lessons learned and observations:
1) the spring catches tend to loosen a bit when i 4-wheel, and if i wanted to fix this, i'd need to use hinges and a latch instead. it's not a big issue, but it's a bit annoying.
2) so far, no issues with the dual-optima setup. the internal resistances of the batteries are identical, and the charging rates seem very similar. i've had no heat buildup or outgassing. the voltages tend to equalize adequately. the starter right now is at 12.56v and the deep-cycle is at 12.91v. given that they shipped at 13.44v each i'm not too concerned. i'm thinking of getting a panel voltage readout to keep an eye on the deep-cycle anyway, so if it gets a bit high, i can turn it off and start using it.
3) the 3" memory-foam mattress is awesome, and knox foam is a winner of a company. i went cheaper with the foam elsewhere, but got the mattress cover from knox foam. great guys, highly recommended.
4) the forward compartments tend to not get used a lot since they're hard to get into with the mattress on top. i find myself kind of wishing i had my toolboxes somewhere more convenient, but that more convenient space is used by other stuff.
5) the painless wiring system is indeed painless. if you get one you'll see that you don't have to exactly follow their instructions concerning the order, but most everything does have to be completed. no missing parts...always good.
6) getting in and out of the back with the platform in it sometimes results in hitting the interior light. if yours is mounted in the rear, below the third brake light, be careful or you'll hit it with whatever... back, hip, head.
7) i still haven't figured out a proper spot to use for the tie-downs for the water jugs.
__________________
My truck page
Photography:
Old 06-08-2006, 06:09 PM   #29 (permalink)
PeanutRanger's Avatar
That is great man, really thought out and planned good. I love to camp sleep outdoors etc. I'm jealous!
__________________
86 4Runner, SR5, Turbo
KC Hilites Bar
4 - 6in HELLA 500's
PeanutRanger is offline
Old 06-08-2006, 06:18 PM   #30 (permalink)
snap-on's Avatar
Send a message via AIM to snap-on
so hears a fairly odd question but one that can only be answered by those that have such a setup....
do you sleep head by the cab, or head by the tail gate and why?
__________________
94 EX cab, 5speed, V6, locked, ARB bar, NWOR headers
92 4runner, auto, V6, OME suspension, Downey headers
snap-on is offline
Old 06-08-2006, 07:09 PM   #31 (permalink)
USAtruck6's Avatar
Send a message via Yahoo to USAtruck6
Real sweet! You planned it out perfectly.
USAtruck6 is offline
Old 06-08-2006, 07:12 PM   #32 (permalink)
i have a 4runner that has a platform that we sleep on. we sleep with our heads towards the tailgate. it makes getting out easier. but the key is to make sure that when parking, the tail end is level or a little higher than the front end.
bob
Bob_98SR5 is offline
Old 06-10-2006, 07:54 PM   #33 (permalink)
photoleif's Avatar
thanks for your kind words (USATruck6 and PeanutRanger). so far so good with the platform (can't say as much for the CVs... but that's another sob-story). we sleep with heads near the cab, since i designed the space at the end to accommodate muddy boots, etc. i also kind of like sleeping with my feet hanging off a bed (dunno why... don't ask, don't know) so the gap facilitates that. the mattress does tend to get a bit dusty despite the sealing i did around the tailgate and such. i will do a bit more to try to tighten up those gaps.
__________________
My truck page
Photography:
Tags
bed, build, cruiser, dodge, fj, making, pickup, platform, plywood, rack, roof, sleeper, sleeping, storage, truck, wood
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
4runner sleeping platform! olsy1984 95.5-2004 Tacomas & 96-2002 4Runners 2 05-01-2007 06:05 PM
Drawer/sleeping platform Help please!?? SOAZtim 95.5-2004 Tacomas & 96-2002 4Runners 1 02-01-2007 02:59 PM
Sleeping platform blueprints Roboito 95.5-2004 Tacomas & 96-2002 4Runners 13 10-04-2006 08:15 AM
Sleeping Platform - Tacoma trucks photoleif Off Road Enhancements 0 04-15-2006 09:26 PM
2009 InternetBrands, Inc.
