Slave cylinder trick?
Old 11-16-2009, 07:34 PM
mmcpeck's Avatar
Anybody got any tricks to get the line off the slave cylinder of a tranny behind a 3VZE?
The thing is pressed right up agaiunst the tranny, don't even see how you could get a wrench on there and have any room to turn it.
Not even a slave cylinder is easy on this truck!!
Old 11-17-2009, 08:00 AM
mmcpeck's Avatar
Somebody's gotta have some advice for getting to that hydraulic line on the slave. I know it's been and can be done, just don't see how you get a wrench on the line.
Thanks.
Old 11-17-2009, 01:15 PM
thedanned's Avatar
Try a crows foot wrench? Never had to do this before. Ill look at mine when I get home.
Old 11-17-2009, 03:16 PM
jreb10's Avatar
I took off the slave on my 1992 3VZE a couple of weeks ago. I used a standard Sears Craftsman wrench (10 mm I think). I reached up from below the connection, sort of, and was able to get enough rotation on each pull so the open end wrench was able to re-engage the fitting. I do recall thinking that a shorter wrench would have been handier.
Try sneaking the wrench up there as far towards the front of the truck as you can. It worked for me.
RobotMoose
02-22-2020 07:44 AM
4.34runner88
02-07-2016 02:24 AM
93toyoguy
3.4 Swaps
10
09-18-2015 04:16 PM
Squigglez
09-04-2015 07:33 AM
Quick Reply: Slave cylinder trick?
