slave cylinder
Old 04-16-2013, 11:31 AM
chicagopetedagreek1's Avatar
slave cylinder
is there some kind of proportioning valve for the slave cylinder on a 89 pick-up 22RE 4wheel dr. 5 speed?
Old 04-16-2013, 12:20 PM
xcfunrunner's Avatar
Proportioning Valve
There is a proportioning valve for the brakes. There is a rod connected to your rear axle and is attached on the upper right side of the truck under the bed. As the truck bed is loaded down with weight, the distance from the rear axle to the proportioning valve changes. This changes how much "power" is going to the rear brakes. The proportioning valve is separate from the slave and master cylinders on the brake.
That is what a proportioning valve does. And yes, you do have one. However, it is not connected to the slave cylinder.
Old 04-17-2013, 04:26 AM
Staff
Terrys87's Avatar
xcfunrunner...I never thought of the weight factor being added in there and causing it to adjust. Great explanation on that. Thanks!!
camel_65@hotmail.com
10-03-2018 06:11 AM
mxdw88
09-20-2015 03:13 AM
93toyoguy
3.4 Swaps
10
09-18-2015 04:16 PM
scheuvront1993
09-17-2015 06:17 PM
Quick Reply: slave cylinder
