simple question, compression check
Old 06-04-2008, 02:05 PM
76ANTHONY's Avatar
can you do a compression check on an engine before you install it? just want to do this rebuils once and not have a bunch of pulling it back out issues...
Old 06-04-2008, 02:23 PM
abecedarian's Avatar
you could get it mounted to a dyno and run it that way.
otherwise, a leakdown test is the best you can do without much problem.
Old 06-04-2008, 02:25 PM
Cyberman's Avatar
I just ran a compression check on my engine. Granted it's mounted on the frame, but there is nothing else hooked up to it. You'd need to mount the transmission and starter on the engine, then wire up the starter to turn the engine over for the test. The only thing this will do is let you know you have compression, and maybe check to make sure it is consistent between cylinders. It is recommended that the compression check be done on a warm engine, which is obviously impossible without installing it.
Old 06-04-2008, 04:23 PM
76ANTHONY's Avatar
kinda what i thought, dam......
Sleaker
08-26-2020 06:03 AM
the1998sr5
15
07-14-2020 08:35 PM
thefishguy77
07-30-2015 10:59 AM
rushw
07-18-2015 01:46 PM
Coreyr384
07-10-2015 11:13 AM
Quick Reply: simple question, compression check
