shuddering in 2WD drivetrain on takeoff
I have an 87 2WD Toyota longbed Pickup. About 6 months ago the truck started shuttering every once in a while when taking off from a full stop. The shuttering is pretty violent; It feels like the truck is shaking its self apart. It happens consistantly when you have a load in the bed and especially when you are starting on a up-hill. Reving up the engine and releasing the clutch slower for the most part makes the problem go away. Its gotten worse recently and will do it without a load in the bed especially when you release the clutch at low RPM to the point where the engine boggs slightly; I'm guessing around 800 RPM.
I climbed under the car and shook the crap out of the drivetrain thinking it may be a U-joint or driveshaft support bearing but I did not notice and play. So I'm thinking motor mounts or specificly the rear transmission mount. Any thoughts on what it could be or what else I can look at? Thanks!
It seems to do it consistantly when going uphill, so maybe I'll do it with some ramps in front of the front wheels. I guess the real test to determine if its u-joints or engine mounts is if I can get it to shutter without the wheels moving.
I'm leaning towards motor mounts because like I said in my first post: If you rev the engine up and let the clutch out slowly the truck won't shutter but If the RPMs are low in the same situation, the truck will shutter.
Anyone know how much the engine should jump around under load?
My brother replaced the clutch... If the driveshaft is rotated 180 degrees from how it bolts on in the rear diff. would this make a difference? I remember the FSM saying something about marking the position of the driveshaft in relation to the rear diff. input flange.
TheBFA
02-15-2020 06:55 AM
Dale Johnston
11
10-31-2015 10:22 PM
JookUpVandetti
09-30-2015 08:58 AM
