Shop says I need a new engine
Old 09-07-2012, 08:53 AM
killroy's Avatar
Helo all, this is my first post. I have a 94 X-Cab DX that is not running well. Took it to a shop, this is what they said:
"Check and advise, find chlinders 3 and 6 not firing. Compression test cylinders 3 & 6 find no compression. perform cylinder leak down test, find cylinders 3 and 6 exaust valves leaking at 95%. Also cylinder 1 rings sealing at 50%. Recommend engine swap due to cylinder 1 leak".
$3,800 was the quote to swap out. I don't have that at the moment. The neighbor got a used engine from Japan for around $1,000 and put it in himself some years ago.
I still drive it to the dump and to get lumber or dirt for the garden. Getting about 10 MPG. It shoots a lot of unburned fuel vapor out of the exhaust. Is there a way to disable the injectors to cylinders 3 & 6? Is this advisable?
Thanks
Old 09-07-2012, 09:18 AM
waskillywabbit's Avatar
3.0 will still be a 3.crap
3.4 swap or sell it and cut your losses.
:wabbit2:
Old 09-07-2012, 04:20 PM
TNRabbit's Avatar
And driving it on three cylinders is just ridiculous!
Old 09-07-2012, 04:32 PM
bjlambert's Avatar
Try unplugging or crossing the wires on said injectors, helluva plan though I must admit.
Old 09-10-2012, 12:42 AM
ilovelivinginthecity's Avatar
Old 09-10-2012, 12:47 AM
snowshredder555's Avatar
My vote goes for the 3.4 swap...sold my 90' with the 3.0 for a 97' with the 3.4 and lovin it!
bigjstang
08-25-2021 12:41 AM
icentropy
09-16-2020 02:47 PM
Colington
03-08-2020 09:51 AM
Eggslinger
06-08-2019 03:32 PM
skoti89
07-08-2015 12:05 AM
Quick Reply: Shop says I need a new engine
