Shock Question. Pick-up vs 4Runner
Are the front shocks for a 88 pickup and 4Runner interchangeable? I though they were but for some reason there is only one or two pro-comp shock coming up for a 4runner on the 4wheelparts/pro-comp website while for the pickup there are 8. Idk if they just didn't update the 4runner section or if in fact they are different.Thanks,
Also, anyone know what would cause the shocks to get damaged by the bump-stops? at first i though it was because the shocks were not long enough but I checked the model number and they are for a truck with 3" lift (Rancho RS5136. 17.3" expanded 11.25 collapsed). You guys think the shocks are shot?
Much Better pics if you follow this link:
http://imageshack.us/g/521/imag0745.jpg/
yes they will limit the travel but is it worth ruining shocks? You could maximize it by unbolting the bottom bj and compressing the arm till the shock bottoms then make the new stop spacer 1/4-1/2 in longer to stop the compression before you break things.
jasonty
41
12-23-2018 01:00 PM
BeMiceElf
10-10-2015 09:40 PM
rushw
07-18-2015 01:46 PM
FS[NorAtl]: some RC stuff crawler and racer
akaphilly
07-09-2015 02:34 PM
